E350 Winnebago help
Old May 9, 2021 | 08:40 PM
Dustman3's Avatar
Dustman3
E350 Winnebago help
1987 E350 with 460. Cranks and idles like a champ, but when you rev to mid to higher RPM it starts busting out. What I’ve replaced so far.
fuel pump
fuel filters
rebuilt carb
plugs
coil
switched coil out and it was fixed, until today. I have put four different coils on it and it’s not fixing it this time. Any help is Appreciated
Old May 11, 2021 | 04:10 AM
BLK79's Avatar
BLK79
Check the supply fuel line from tank to carb, may have a small crack or hole in the rubber sections. Also try loosening or removing fuel cap temporarily.
A couple other ideas are ignition module and pick-up coil/pip sensor (whatever it's called) in distributor. Although when I've had either of those fail - they'd quit when hot - as in truck dies and/or won't restart until cooled off.
Old May 11, 2021 | 11:44 AM
Dustman3's Avatar
Dustman3
So far so good
Switched out the ignition control module last night and it so far it has worked.
MontyHowie
Jul 10, 2019 12:54 AM
Burnsumtire
Nov 26, 2017 02:29 PM
greasefingers
Jul 6, 2010 07:20 AM
mohara81
May 12, 2006 01:20 PM
AaronW
Aug 27, 2002 09:54 PM
