Fuel Pump ?
Old Aug 26, 2002 | 11:01 PM
AaronW's Avatar
AaronW
Fuel Pump ?
truck doesnt really cut out but it bogs and stumbles when given throttle under load. Idles like crap, but revs fine in neutral. I tried adjusting the carb and at first it helped, but before I finished tuning, the idle dropped and would not come up. I say fuel pump, sound right?
Thanks
AW
Old Aug 27, 2002 | 02:08 AM
Scotty1's Avatar
Scotty1
Fuel Pump ?
To rule out the Fuel pump I would get a Fuel pressure gauge. You can get them at most parts stores, and they mount between the pump and carb. But, while I was reading I kept saying to myself sounds likie timing. I could be wrong. I would look in to the distributor as a possible problem. If it is origanl it needs rebuilt no matter what anyway. Even if it isn't the problem. I hope this helps and someone will give more info.
Scott
Old Aug 27, 2002 | 06:22 AM
William's Avatar
William
Fuel Pump ?
I would start with a ignition tune up. That simple process will eliminaste most crappy running situations. Then move to the fuel system. Are you running points? Are the plugs in good shape? Cap, rotor, wires?
William in Atlanta
Old Aug 27, 2002 | 07:52 AM
AaronW's Avatar
AaronW
Fuel Pump ?
Everything in the ignition is less than 5 months old, checked the points gap, its fine. I did not replace the coil.
AW
Old Aug 27, 2002 | 09:44 PM
AaronW's Avatar
AaronW
Fuel Pump ?
How would I test the coil?
AW
Old Aug 27, 2002 | 09:54 PM
FTE Ken's Avatar
FTE Ken
Fuel Pump ?
Kenmc
13
Jun 10, 2016 08:55 AM
idonoe
Oct 8, 2015 11:27 AM
smiley87
Modular V10 (6.8l)
Jun 26, 2015 04:49 PM
78fordranger
23
Apr 3, 2008 01:40 PM
packrat56
Nov 12, 2004 10:21 PM
