Oil galley plugs
Believe their tapered, thats how they get tight. Should all be NPT threads. Just got mine back but they installed all new where they removed them.
count id think every threaded hole except the oil pressure sensor. I'll count mine and where they are tomorrow, but its a 400 not sure how different they may be.
Do you have the plugs?
Internally, all the oil galley plugs are press in, kinda like miniature freeze plugs.
There are three located in the valley at the back of the block. At the front there is one located in the valley and two that are accessed from the front, behind the cam gear.
Be sure to look carefully, one of the two is hidden, deeply recessed in the block.
All the external plugs have a pipe thread.
You can see the hidden plug deeply recessed past the distributor hole.
The following users liked this post:
