Lost Power/Boost
Old May 3, 2021 | 12:02 AM
spence13e's Avatar
spence13e
Lost Power/Boost
Same 2004 F250 I've had for 15 plus years. Almost 275k on it now. When it got bullet proofed 100k ago, the hot side boost boot took a dump and the shop stuck a scab they had laying around on it. Kept running fine until the last few weeks. Have a guy about 20 min away that's been working on mine. He is a couple months out to work on stuff, but said replace that boot. Didn't do any good. To me, while driving, it sounds almost like an old gas engine with an exhaust leak out the manifold. Any ideas what the issue is here? I hate to do it, but I kinda need the thing and don't know that I can wait that long to get it in.
Old May 3, 2021 | 07:28 AM
F350 1990's Avatar
F350 1990
Given the sound you've described it appears to be a simple leak. Locations (some candidates):
Manifold and turbine housing
Compressor manifold hoses
Not sure how old that turbo is but it's probably also do for a cleaning, rebuild or replacement --worn out turbine, compressor wheel, bearings, etc. I like using the 03-4 Turbos (even on the newer, but you have to adapt for mounting changes)-- sound better, more geddy up, faster spool up.
Old May 3, 2021 | 07:48 AM
spence13e's Avatar
spence13e
Turbo was replaced under warranty at around 40k in 07. I was deployed when I bought the thing and it sat a year and a half before I got to drive it, ate the turbo in the process.
I’ve got a couple other issues that need addressed before I can really drive it any more. It got all new injectors in the last six months, and I hadn’t really had to do a lot to her in a while, so I suppose it’s just that time.
Old May 3, 2021 | 11:37 AM
Jimmy Dean82's Avatar
Jimmy Dean82
was there a pop when it happened? I've lost a few boots. replacing it is not just simply replacing. you need to degrease the metal, check for warpage of the flares, it can help to scuff it with steel wool as well. I have seen some people put on hairspray to help it stick as well until it really seats after a few heat cycles. The most common boots I've lost are right after the turbo, and right before the intercooler.
Old May 3, 2021 | 02:18 PM
FiveOJester's Avatar
FiveOJester
I would check all of your boost on the boost side (hot & cold side of intercooler). Usually you can spot the leak as it will be oily with residue from the CCV system. They are all pretty easy to change. Get a quality boot like Riffraff or Motorcraft if you prefer OEM.
Old May 3, 2021 | 09:48 PM
IHateCommieCars's Avatar
IHateCommieCars
Do you have the plastic CAC tube on the driver's side going to the intake elbow? If so, it cracks a lot down at the intercooler. That's where you'll see the residue 50 refers to. I'd hunt the pic-u-part yards for a metal one.
Old May 4, 2021 | 04:38 AM
bismic's Avatar
bismic
Post deleted, put it in wrong thread (duh)
Old May 4, 2021 | 10:47 PM
spence13e's Avatar
spence13e
No pop. However, that old boot was worn the heck out. I was unaware that I needed to clean it up when putting the new one on. Got to get brakes/power steering fixed later this week, it's sitting in town. I'll try and mess with it when I get it back from up there.
Zerojunk
Aug 28, 2013 09:06 AM
jermort
6.7L Power Stroke Diesel
13
Jul 3, 2011 09:59 AM
PJ-Hunter
13
Dec 4, 2010 09:30 AM
UP_There
Dec 4, 2008 06:10 PM
tommpa
6.4L Power Stroke Diesel
Mar 18, 2008 05:07 PM
