Factory AC comprssor replacement.
Old May 2, 2021 | 09:09 PM
Denty's Avatar
Denty
1975 F150 Ranger XLT FE390 2WD
So the PO disconnected and removed the compressor at some point, everything else is still there. Are compressors interchangeable or would it be possible to use a more modern compressor from a JY to replace the one that was removed? Or what year the compressors changed. My local PnP usually doesn't have anything older than mid 80's.
Old May 3, 2021 | 05:12 AM
i-w's Avatar
i-w
you will need a bracket if you use the Sanden compressor
ours is a york
the york has a Compressor Output: 164cc/10.0cid so you might want to get a Junk yard one with similar output.
here are a couple places to research the bracket in case you want to make your own.
or buy from them.
https://nostalgicac.com/
https://nostalgicac.com/compressors/compressors.html
https://www.vintageair.com/
Old May 3, 2021 | 08:48 AM
440 sixpack's Avatar
440 sixpack
When the York on my '76 dies this is that I'm going to do. it says '76 to '79. I'm not sure what the difference is for your '75 but I'm sure it can be overcome.
76-79 F-Series Truck/78-79 Bronco AC Compressor Kit V8 STAGE-1 | Original Air Group
Old May 3, 2021 | 09:20 AM
mudbogger2's Avatar
mudbogger2
I would urge you to stay away from Original Air Group. I am still fighting with them over incorrect parts on the Stage 2 upgrade I purchased in January. They are utterly incompetent IF you can get them to answer/return calls.
Old May 3, 2021 | 09:28 AM
ford390gashog's Avatar
ford390gashog
Well take a look at your hoses, they are single wall and often very brittle by now. The only double barrier hose was on the high pressure line to the condenser. I suggest replacing all the hoses and doing a Sanden 508 conversion.
Old May 3, 2021 | 10:15 AM
flowney's Avatar
flowney
If the system has been open to the environment, there is a strong chance that bugs, dust and dirt have compromised it. Replacing the compressor, hoses and (especially) the receiver/dryer are necessary but you'll also want to have the condenser and evaporator professionally cleaned unless you're going to replace those with new parts as well. Finally, you'll also need to consider converting from R12 to R 134a refrigerant.
Given all the work, money and risk involved, you may want to consider a whole new and more modern system. Vintage Air now sells a "Sure Fit" kit for 1973 -79 Ford pickup trucks and the 1978-79 Bronco. That kit assumes a 400M engine so you'd need to get the FE bracket separately.
Old May 3, 2021 | 09:04 PM
Denty's Avatar
Denty
ours is a york
Looks like they literally just cut the lines to the compressor and ditched it. The Bracket is still there, so I got that going for me.
Yes it was just left open. Was planning on new lines and will talk to the local ac shop about cleaning and testing the condenser and evap. Am hoping the majority of the system is salvageable cause I'd rather spend the dough on other parts of the truck.
Old May 4, 2021 | 06:28 PM
HoustonDave's Avatar
HoustonDave
You can try to flush the system with alcohol. If you can find a York compressor good, but the Sanden style is much less drag on the engine. If you convert to R134 refrigerant you will need a new condenser and drier in front, probably new hoses (or at minimum adapters for the banjo fittings) and probably a new TXV, Flush the system with alcohol thoroughly, pull a good vacuum, and if it all seals OK, put in PAG oil and new refrigerant. If you stay with R12, do not switch to PAG oil.
Lights_Guy3
Apr 2, 2016 02:43 PM
jake22si
1997 - 2003 F150
Jun 28, 2015 09:04 AM
Wengnutt
Mar 30, 2005 06:04 PM
