10x15 crager wheels
Old May 3, 2021 | 08:30 PM
Nitro1168's Avatar
Nitro1168
10x15 crager wheels
I’ve been looking for a set of old school crager aluminum slots and finally found a set. Spent hours sanding and polishing them so Sunday I sprayed the cab. Then I went to install the wheels and the front ones hit the dust shield and caliper. I trimmed the shield and grinded the caliper so they would fit. These trucks came with 15” wheels and they are not car wheels. Did anyone ever have the same Problem or knows
why they don’t fit?
Old May 3, 2021 | 08:34 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Wrong backspacing. Look at your tie rod ends. They're probably up against them too.
Old May 3, 2021 | 08:38 PM
ranger140892
Grumpy goat
And another thing...Even if they do have the correct backspacing, aluminum wheels are much thicker than factory steel wheels.
Old May 4, 2021 | 06:03 AM
vtpkrat2's Avatar
vtpkrat2
My "Vision" wheels had proper back spacing,bolt pattern and center hole size but hit the caliper bolt head that holds the brake "slide" in place .Finally replaced the hex head bolt with a Allen head bolt which gave clearance.Dust shield was fine on my 2wd 1976 302. In the long process of reading about wheel fitting for my truck, it seems this is a bit of a struggle but works out eventually.No real answer I guess to your particular problem aside from it seems to be pretty common.
Old May 4, 2021 | 06:54 PM
Nitro1168's Avatar
Nitro1168
Thanks for the replies, backspacing is good, it had chrome 15x10s on it. I guess it is the aluminum wheel thickness
Curated Content Editor
2017 Ford SVT F150 Raptor
Nov 9, 2017 12:00 PM
OEWheels-Tech
26
Feb 9, 2017 09:12 AM
brad2185
Jan 22, 2012 11:32 AM
YoungFordAddict66
Mar 4, 2011 02:51 PM
fordf350camper
Mar 19, 2010 05:24 PM
