This is complete minus the brackets, pulleys and compressor. This may be a better option, as I can source the specific parts for my truck instead of relying on a more generic setup and hoping that the engine hardware fits.
What say you guys?
Are there other options that I have not considered?
I am not familiar with all of those items, but cost is my determinator. I have installed factory A/C one that did not come with it. I was lucky as a friend worked at the junk yard and got everything for me for 150.00. That is, the dash, air box, accumulator, compressor, lines, brackets, and condenser. I actually bout a new accumulator, compressor and orifice as the old stuff does not like 134A and usually do not last long. I do not leave this to the faint hearted or those that do not know there way around the vehicle, but I liked the challenge and it is still running strong after two years.
My '86 F150 has dealer-added A/C--apparently this was common then. If you could find a donor in a junkyard with that setup, it might not be too hard to transfer into your truck.
As I was told and I can say is true the fire walls are different between factory AC trucks and non-factory AC trucks.
The AC fire wall is over the non-AC one and there is more than just cutting that other big hole. I would not tell anyone to go down this path.
I did convert an 80F350 to A/C, but I had a donor truck that had DEALER installed A/C. This was actually a real simple conversion that took me two or three afternoons and was probably the coldest A/C I have ever experienced.
It was a lot of work but it was basically a bolt-in job. I think I had to cut the holes on the passenger side dash, but the rest was just swapping parts. You don't remove much of the original heater system, the dealer stuff is an add-on.
I put an underdash unit in my old '66 years ago..About a weekend job...and you could hang meat in the cab !!..Worked fine...and WAAAAAY easier that trying to add factory unit..
I am about to embark on the same thing. I personally think adding an underdash AC is much easier than trying to adapt/retrofit a factory setup from a donor truck. No need to change cabs/firewalls/change out heater box/etc.
You don't say what your transmission is, but if it's a floor mounted manual, then it's a bigger challenge. I plan to go to a vendor and find the evap unit that fits best. I have the Srod 4 sp which is back farther toward the seat vs a NP435. Even if it's an auto on the column, you might want to pay attention to what fits under there best.
The only donor parts needed would be the compressor brackets, pulleys including for the fan and 3 groove harmonic balancer.
Good luck; I'll post up what I find.
Oh, I'm adding it to a '81 F100, 300 six, Srod 4 sp, 2 wheel drive.
Reason: more info
