I need a replacement carb
I went to Holleys site and found these:
https://www.holley.com/products/fuel...arts/FR-80555C
https://www.holley.com/products/fuel...arts/FR-80783C
I'm not near my truck today so I can't pop the hood to check anything but I believe it has an electric choke because I don't have anyway of turning off the choke without tapping the gas.
Can anyone tell me if either of these will work?
Thanks.
https://www.holley.com/products/fuel...arts/FR-80457S
Thanks.
As mentioned the first one is a Rochester-style spread bore.
Also, that carb will not function with the emissions devices on the truck. If they are still in place you will need to do modifications to fit the carb, Just be aware it is not just a bolt-on.
You can opt for re-man factory carb
https://www.rockauto.com/en/moreinfo...24031&jsn=1538
But they are not cheap either.
Another option is to opt for the summit M2008 Far cheaper than the Holley and comes with full literature on how to tune and set up
The Summit carb is made by Holley for Summit and is basically the old Holley 4010 which in it's self is based on the Ford/Autolite 4100
Your stock carb is 600CFM First link is the 600CFM Carb
The second is the 750CFM one.
https://www.summitracing.com/parts/sum-m08600vs
https://www.summitracing.com/parts/sum-m08750vs
Since you have an auto application you will need the additional Kick down bits
https://www.summitracing.com/parts/sum-m08070
To be honest given the choice I'd take the summit for a stock or mildly modified application over the Holley
The annular boosters in the Summit will provide better throttle response and fuel economy and it is a less costly carb to boot.
