Vacuum hoses and emissions - what can I remove?
Old May 18, 2021 | 07:38 PM
  #61
khyslop's Avatar
khyslop
Originally Posted by matthewq4b
The Idle mix screw location is going to depend in whether it is a Carter YF or YFA.
The idle mix screws adjust the fuel-air mix on the idle circuit. The Idle circuit in the carb is in use at idle and just off idle.
Ideally, you want to adjust them with the vacuum method. You do the maximum engine RPM method only when do not have a vacuum gauge at your disposal as it is not very precise, but it is better than nothing.
Make sure you are at the factory curb idle and at operating temp when starting and that any engine loads are turned off (A/C)
As you adjust the closer to max engine vacuum with the idle mix the engine idle speed will increase. So adjust for max engine vacuum then adjust idle back down to factory settings. Then you readjust the idle air mix for max vacuum again. You may need to do this dance a few times to get it dialed in.
Before doing this make sure your base timing is adjusted. Set yours at 10° BTDC and leave it there (max sure the vac is unplugged when doing this). Then adjust your idle mix/ and idle If you change your base timing you WILL have to readjust your idle mix.
Once that is done see how it runs and you can dial in your vac advance. let us know if you are having any other running issues.
A word of advise stick to following one persons diag suggestions if make it much easier for you and some throwing stuff there is just hoping something will stick with no real clue of the base issue..
I have not seen anything on what the idle RPM is when checking timing and adjusting the idle mix screw?
I say because I saw after your ride and it went bad you got back and checked, readjusted and hooked the vacuum backup the timing advanced?
I have not had this happen if the idle is set right (low).
Dave ----
You can use the vacuum gauge while adjusting the idle mixture screws, or you can do it by ear. You want the engine fully warmed up, preferably after a drive. Let it idle, and then turn one screw in till it runs worse and slows down. Then turn it out till it runs the fastest/best. The go to the other screw and do the same again. In, and then out. Then go back to the first screw and do the same thing again, in and then out till you get it running the smoothest and the fastest.
If you do not get much affect from the idle mixture screws, your idle speed is too high. And that is good advice about the vacuum advance, just leave it unplugged, you only need one battle at a time. You can still play with the timing with the light, and set it up and see how it does. I always found 10 BTDC left a little bit on the table, 12 BTDC gave me a little bit more, 14 will also if it will start hot. There is no rule on this, you can just try different settings and see what happens.
P.S. Sorry, I forgot you are working on a 300 six. You only have one screw to mess with. That will make it easier.
Man, you guys are awesome! So I did what was recommended. Here's how it went. I drove around and got it nice and hot, then when I was going to plug in the vacuum gauge it just dawned on me that all of the old vacuum lines that are not attached to anything are still connected to the manifold. I have been experiencing some dieseling at shutdown, and figured I had a vacuum leak somewhere. I pulled all of the old lines and just capped them, leaving only the brake booster and the hose going over to the heater. Then, when I adjusted the idle speed it actually dropped quickly (usually didn't really change at all not matter how far I turned the screw). The engine smoothed way out, and then I went on with the mix adjustment. I was able to adjust it to just above 21 on the vacuum gauge and it held steady, then backed off about a 1/4 turn. I checked the timing and set it back to right around 10 degrees. It's so hard to tell exactly because of the angle of the markings and the timing mark is underneath it, but I think I'm close. I took it for a drive and at a light I had to roll the window down to see if it was actually running... I got so used to the high idle. I ordered an aftermarket tach for it so I can get the idle speed dialed in more than by ear. I'll go through this process again once I get it hooked up.
After that, I'll revisit the vacuum advance issue. Dave, I hope that the high idle was a factor and that it will work now!
Ok, now that that seems to be settling down and I have learned a TON about timing, distributors, idle mix, etc. (thanks BTW!), let me direct this back to the original purpose of the thread. While I wait for the tach to arrive I have all of these vacuum tubes that are not connected to anything. Can I just pull it all out? There was one vacuum line that went from the manifold and just poked out of the wheel well. I have capped it as well.
You can see the two lines that are still connected, the rest were capped and it smoothed out the idle.
There's also a MAP sensor on the side that is not connected to anything but an unplugged vacuum hose. Can I just take this off?
I assume this is a MAP sensor based on the vacuum diagram under the hood.
Take it all out? I know I'll have to fish out the wires that are actually being used from this mess, but does the rest just come out? Computer under the dash, take it out?
I don't know what the thing is on the left.
These may be stupid questions, but I'm hoping to clean it up under the hood and only keep what I need now that I have that old distributor out. There are so many disconnected wires, red, yellow, and black vacuum hoses coming from the harness on the valve cover. I just don't want to screw anything up.
Thanks again!
Kevin
Old May 18, 2021 | 08:10 PM
  #62
matthewq4b's Avatar
matthewq4b
Since you are not using any of that stuff pull it off and cap the vaccum sources.
We will have to sort out your evap also eventually.
Old May 18, 2021 | 08:14 PM
  #63
khyslop's Avatar
khyslop
We will have to sort out sort your evap also eventually.
Oh boy, I'm afraid to ask. What do I need to do to the evap?
Old May 18, 2021 | 08:40 PM
  #64
matthewq4b's Avatar
matthewq4b
It will be easy just running hoses, at most you will have to pick up a purge valve.
Old May 18, 2021 | 08:59 PM
  #65
khyslop's Avatar
khyslop
is that because the thing on the left is the evap canister and it is no longer connected to the computer? Will I be adding a different system to deal with the evap?
Old May 18, 2021 | 09:45 PM
  #66
matthewq4b's Avatar
matthewq4b
Yes the solenoids that controlled the Evap system are no longer controlled by ECU. So something needs to be put in their place. There are a couple of options you have avalible.
Ideally, you should post a pic of the underhood with the air cleaner removed and I can highlight everything you can pull out. Save the hoses though, until a decision is made is about the Evap
Old May 19, 2021 | 07:07 AM
  #67
khyslop's Avatar
khyslop
I can take a new one later if necessary, but here is one I posted earlier that shows everything that was on there. (I do have a PCV valve, it's just out in the pic)
On the manifold port, there is a "y" connection that has one end capped with a short hose and bolt and the other end has a hose that pokes out of the wheel well to daylight. I have removed this and capped it at the port. Next to that is a hose that runs to the disconnected MAP sensor, and the red vacuum tub from the solenoid T's into it. The other vacuum hoses at the manifold are the one to the brake booster and the one that goes to the vacuum tree on the firewall. As for the colored plastic tubing, the red is connected at the T with the MAP sensor, the white is disconnected and hanging there, and the others are just cut.
Here are the two hoses that I unplugged and capped the port.
The two hoses I removed are still under the hood, in case I need to put them back for some reason.
Old May 19, 2021 | 01:35 PM
  #68
Max Capacity's Avatar
Max Capacity
The only input I have here is to check those black caps you used on that vacuum tree in a few years, they don't last forever.
Old May 19, 2021 | 05:02 PM
  #69
matthewq4b's Avatar
matthewq4b
Its a start but need the WHOLE of the underhood from fender to fender to firewall to rad support.
The stuff you removed and hooked, Remove it from under hood the Map sensor leave in place, for now, remove the hose though.
Since i"m doing this remotely I will highlight some stuff that can come out, once you pull it and remove it from under hood and take another pic with it removed so I can go onto the next things.
If you are patient and want to do this correctly and I can keep the peanut galley from running this off in the weeds when it is done it will look a factory installation.
Once you have pulled this stuff below that is highlighted in red and it's associated wiring Take another pic of underhood from fender to fender to firewall to rad support.
If you have questions feel free to take a pic and ask. I have no issues working with you through this for as long it takes for you to have a clean factory-looking install.
Remove one wire at a time. Cut it off from the connector at the solenoid then unthread out of the wiring harness back to it's source, if it splices into another wire cut off the other wire it at the splice. DO NOT cut the wire it is spliced into.
Some of these will be ground wires that will ground other items. If the wire is part of the EECIII control system it will be pulled out later on.
Old May 20, 2021 | 06:56 AM
  #70
khyslop's Avatar
khyslop
Perfect, I'm actually looking forward to this. I'll get all of that stuff pulled out and post some updated pictures.
Old May 20, 2021 | 06:54 PM
  #71
khyslop's Avatar
khyslop
alright, before I get too far. I have everything unplugged from the solenoid and the solenoid removed. Do I cut into the big wiring harness at the firewall and take all of the wires back to the source inside the truck?
Solenoid removed
Crack into this and remove the wires?
Connections to solenoid
Also, I have separated all of the wires that are actually plugged into something from the ones leading to unplugged connectors. Can I just cut these connectors off and fish out these wires as well? It’s a rats nest and I can’t untangle them without cutting them. There’s a lot of them.
All of these go into the wiring harness and are unplugged.
there’s also several other loose connectors floating around that come in from other spots but I’m not worried about them.
Old May 20, 2021 | 07:16 PM
  #72
matthewq4b's Avatar
matthewq4b
Yes and yes, you will find most of this stuff (wires) goes to the ECU/ECU connector inside the truck. Fish back to the ECU Connector and cut off from the conmector. DO NOT just cut the EEC ECU connector off as there will be some wires you may want to utilize later on for power assesories and if they are still on the connector they will be much easier to identify them. Also, some stuff will go inside the truck and it will make it much easier to identify later in the process if it is left on the connector.
Any dead connectors that were from EEC III components can be cut off and the wires fished out also. If you are not sure what it was from, leave it, take a pic of the connector and the wires feeding it and I will be able to tell you if it can go also
Old May 20, 2021 | 10:42 PM
  #73
khyslop's Avatar
khyslop
So, I have everything unwrapped and ready to cut. I'm trying to understand what you mean by "DO NOT just cut the EEC ECU connector off as there will be some wires you may want to utilize later on for power assesories and if they are still on the connector they will be much easier to identify them. Also, some stuff will go inside the truck and it will make it much easier to identify later in the process if it is left on the connector." Do I cut the connectors that are in the engine bay, and then pull them into the truck and cut them off at the ECU, or do I leave the connectors on the ends of the wires and cut them off at the ECU? What am I not supposed to cut off for possible future use? Or do I cut them a little long at the ECU so that I can identify the wire by the color?
Do I cut them off here and pull through the firewall?
Old May 20, 2021 | 11:51 PM
  #74
matthewq4b's Avatar
matthewq4b
The ECU connector inside the truck for the computer, pull wire back to that and cut them off but do not just cut the ECU (computor) connector off inside the truck.
You can cut the wire off the connectors where ever you like. I tend to cut them about 2"-3" back from the connector so I can reuse the pins or the pig tail if I need too and still have good lengths of wire on hand for whatever. But you can cut them off where ever.
Old May 21, 2021 | 06:36 AM
  #75
Franklin2's Avatar
Franklin2
I would not cut the ECU connector off, and I would not cut the wires either except the few that you have to. I would unplug the ECU connector, and fish it through the firewall whole. It fit through on my Bronco, they had a large rubber piece that went around the wiring and sealed it. Just push that rubber piece through and the ECU plug will fit through the large hole in the firewall if you kink the wires around on the connector.
On mine I remember the main power relay was under the dash near the computer that powered the ECU system. I think I remember there may have been a wire or two that I had to cut and tape up, but the majority when through with the connector.
Then once you are on the firewall side, it's pretty self-explanatory. You will find most wires go to connectors that you have already unplugged. There may be a few wires that are tied into the harness. Make note of these and cut them off the ECU wiring. You can use masking tape to mark them to help you remember what went were in case you make a mistake.
