2008 plus transmission differences? Rsc flex fuel?
Need a 2011 e250 transmission. I have rsc and flex fuel. I know there is a model number for the trans but will a 2008 up w a 5.4 motor transmission work? Does rsc and flex fuel matter?
transmission lost reverse but will go forward . No check engine no real signs beforehand besides we were kind of off road but nothing crazy. Have not pulled codes. If any, thank you!
Post a photo of your van's door jamb sticker showing its built as data like this:
The field shown highlighted in green is the information you'll need to ID which transmission is installed in the van. Your's will NOT be the same as show, this is an example where to look.
You can also post that information in the transmission sub-forum if no one here can help.
