Brake Booster Set Up
Old Apr 28, 2021 | 08:12 PM
Vandy23's Avatar
Vandy23
Last week I had a brake booster and dual master set up installed on the truck. Kept the drums all way around. Long story short looks like the shop did not adjust pin/rod between booster and master correctly so front brakes basically burned up after driving less then 70 miles. Shop fixed everything and properly set pin/rod but is now not happy with starting brake pedal height from floor. Said I t’s too low? Anyone else set one of these up and had any issues or have advice on how to get the proper starting pedal height?
Old Apr 28, 2021 | 10:44 PM
lizardman1's Avatar
lizardman1
Is the booster a factory unit or aftermarket? Are the brake shoes adjusted correctly? The pedal rod can be adjusted for height as well. At least on the aftermarket units. I think the Bendix units too.
Old Apr 29, 2021 | 07:41 PM
Vandy23's Avatar
Vandy23
Aftermarket booster. After looking at the set up I ordered a pedal rod extension. I’m hoping that does the trick!
Old Apr 30, 2021 | 08:42 AM
Crop Duster's Avatar
Crop Duster
If you are using the original pedal the bolt that holds the rod to the pedal is eccentric Just loosen the nut and turn the bolt to move the pedal. In your case it may not be enough to get it where you want it.
Old Apr 30, 2021 | 05:35 PM
Vandy23's Avatar
Vandy23
yeah using original pedal. The rod from booster is all the way extended and the pedal sits really low. MP Brakes has an extender just for this issue. Hopefully that will fix it.
jchav62
Apr 5, 2024 02:53 PM
grinnergetter
Sep 27, 2015 09:20 PM
Jeepers2003
Sep 6, 2010 10:47 PM
dantsg
1997 - 2003 F150
Jul 27, 2008 05:04 PM
goldigr
Nov 4, 2003 07:55 AM
