rocker panel fit ??
Old Apr 24, 2021 | 03:07 PM
old22fan's Avatar
old22fan
Trailering
Question rocker panel fit ??
Old Apr 24, 2021 | 03:09 PM
old22fan's Avatar
old22fan
Trailering
question is this a common issue ?? everything else seems to fit nicely but the big gap in the front.. thanks.
Old Apr 27, 2021 | 09:56 AM
Rockabilly_74's Avatar
Rockabilly_74
the ones I did fitted better than as your pics show.. is your Cab still in correct level? I see you only hat bars from front to the end, not from floor to top? I had to level the cab a bit, but I had to remove the complete floor, rockers and front sheet.
Old Apr 27, 2021 | 12:04 PM
56panelford's Avatar
56panelford
Rocker looks to be in the correct orientation to the cab mount, most important part. I'd just add an extension to tie it in to the triangle brace..
Old Apr 27, 2021 | 09:32 PM
old22fan's Avatar
old22fan
Trailering
thanks for replies, i have cab supported by braces in the front and set the level to match frame before I started. I'll make pieces to fix issue. thanks again
Old Sep 13, 2021 | 07:30 PM
old22fan's Avatar
old22fan
Trailering
one side done.
ready to start the other side
54TexasF100
47
Jan 19, 2023 09:11 PM
1964 MP&L F100
1947 and Older Ford Trucks
18
Dec 8, 2021 12:47 PM
bjmayberry2
19
Nov 19, 2018 06:39 PM
Fly48
Sep 21, 2017 09:09 PM
gdub
54
Feb 10, 2016 10:43 AM
