Intake manifold problem.
Old Apr 23, 2021 | 02:08 PM
Ballsy Halsey's Avatar
Ballsy Halsey
6th Gear
1977 F-350, 351M with propane conversion. I'm doing a complete upper rebuild, head gaskets, intake etc. I'm having a hard time getting the freaking intake off of the motor. Any suggestions? There's only 8 bolts, right? I'm not missing anything here? I feel kinda dumb honestly.
Also, any other tips, pointers or suggestions for doing this head job would be greatly appreciated.
Old Apr 24, 2021 | 08:21 AM
Crop Duster's Avatar
Crop Duster
Actually there are 12 bolts. 8- 3/8 and 4- 5/16.
Now would be a good time to buy yourself a shop manual. It will explain all you will need to know about taking it apart and more importantly putting it back together.
Old Apr 26, 2021 | 11:09 AM
Ballsy Halsey
6th Gear
Ok. So total brain fart. After you said there were twelve bolts, I went back and looked. I have done an intake before, and this is my first on a 351. I came here cause I was tired and frustrated
They are gone. One is snapped off, and the other three are missing. So now I'm not sure what the heck to do.
Old Apr 26, 2021 | 11:46 AM
Crop Duster
Some one may have glued it on with silicone at sometime in it's life. What I do in those situations is put my lifting plate on the carb pad. Hook the engine hoist to it and put tension on it. Come back the next morning and 99% of the time it's hanging there loose. If you don't have that stuff and it has silicone on the china walls you will have to use something to cut it loose. Then pry it off.
Old Apr 26, 2021 | 12:43 PM
beartracks's Avatar
beartracks
Therre are some bosses on the side of the manifold. You can get a pry bar under them and try to gradually work it loose.
maxtor
Apr 16, 2009 07:57 PM
79f100six
Oct 24, 2007 02:25 AM
Green Streak
Jan 9, 2006 09:23 AM
custom_truker
Dec 4, 2003 10:33 AM
