autohubs worthless unless moving
Old Apr 15, 2021 | 09:37 PM
davidpacificnw's Avatar
davidpacificnw
anyone else have an issue with autohubs? Was climbing a snowy hill on a back trail. Had it in 4wd. Got stuck. Stupid truck wouldnt move in 4wd with elocker engaged. dug it out and got it to move a bit but slid into a small gully. Turns our the front wheels weren't turning. By the time I figured it out, I was in way to tight a spot to try to get it out.
WTF are autohubs worth if they don't work. As soon as I locked them in the front started turning, but it was too late. had to have a dodge pull me out by dragging my *** end sideways out of the gulley.
Old Apr 15, 2021 | 09:47 PM
Desert Don's Avatar
Desert Don
Every one has an issue when the system fails........and fail they will, at the most in-opportune time. But that is why they also have the “LOCK” position on your hubs. A fail safe back-up that will work when the “AUTO” system fails.
EDIT: PS. When ever I would go out where there “MIGHT” be a chance of failure, I would turn them to “LOCK” before ever needing them. That way when I flipped the switch on the dash, I always had 4WD.
Old Apr 15, 2021 | 09:57 PM
Desert Don's Avatar
Desert Don
OP; your auto hubs are vacuum operated. Evidently your vacuum system has failed. Broken vac line to hubs, seals in hubs leaking vacuum, vac pump not operating, whatever the case may be.
Old Apr 15, 2021 | 10:02 PM
davidpacificnw
Desert Don,
Thanks, It appears that for whatever reason, there was not enough vacuum to engage them,.
Old Apr 15, 2021 | 10:05 PM
davidpacificnw
Be glad there was a Dodge there to help you in your time of need.
And your hatred is too small.............I hate them all. They are all over priced POS that WILL fail at the wrong time. FoMoCo included.
All fair points. And, definitely will manually engage b4 I need them next time on the trail. Cheers.
Old Apr 15, 2021 | 10:08 PM
JayCarver's Avatar
JayCarver
OP what’s your year and mileage?
Old Apr 15, 2021 | 10:09 PM
cat-alac's Avatar
cat-alac
Isnt that the whole point of the auto / manual hubs? Situations just like that.
Old Apr 15, 2021 | 10:10 PM
davidpacificnw
2018 PSD Crew Lariat Ultimate. It has 25k miles.
Old Apr 15, 2021 | 10:14 PM
davidpacificnw
I would have thought. I was in the middle of nowhere on a trail. The guy who gave my rear and a jerk out of the gulley was a local mechanic. He said the auto hubs don't work at low/no speed. Honestly, we usually take the Rover in snow and I just never have to think about it. We were six hours from home looking for property and fortunately, my real estate agent had a friend who new where we were. Oh well. lesson learned.
Old Apr 15, 2021 | 10:36 PM
Desert Don's Avatar
Desert Don
Well, that paticular mechanic was wrong. Ford’s auto hubs work fine at low/no speed if everything is up to snuff. I.E. no vacuum troubles.
IIRC, back in the early 80’s GM had some auto hubs that would not work unless moving; but that was like 40 years ago.
Old Apr 16, 2021 | 12:51 AM
Flyct's Avatar
Flyct
FTE Community Team
Slightly off topic, I find when I switch from 4WD to 2WD it takes a few feet of rolling before the 4WD disengages. Same on last 4 Ford superdutys. I wonder if the same delay occurs when engaging 4WD and that’s what the OP experienced.
Old Apr 16, 2021 | 06:27 AM
Desert Don's Avatar
Desert Don
I would say no. I have been in situations like on wet grass, switched to 4WD and could hear the hubs engage (when I could still hear)! Did not need to move a couple feet; just switched to 4HI and gave it slight throttle, click-click, and drove away.
Old Apr 16, 2021 | 06:42 AM
harmanrk's Avatar
harmanrk
1, If we are going to nitpick your and you're, lets all point our that there has not been a Dodge truck made since 2009! It's RAM now, even says it in two foot letters on the tailgate.
2, The tire needing to rotate for the auto-hub to engage thing, There is a chance, that when they engage, the splines on the axle do not line up correctly with the splines on the hub. People argue, you have to be moving so the tire turns the hub, then when the splines do all line up, they will slip together and lock up. However this missed two key points, 1, once the transfer case engages, the axle starts turning and will line up one the splines, they do not know if the hub, axle, or both are turning, as long as you don't just smash the peddle to the floor, and let the axle turn slowly it will work, 2, the same misalignment can happen when turning the hub to lock manually, if the splines hit head on, rather then meshing together, they will require the hub, axle or both to rotate so they can mesh together.
Old Apr 16, 2021 | 07:41 AM
Desert Don's Avatar
Desert Don
That was why, with the early Warn hubs, it was sometimes necessary to even rock the vehicle back and forth a bit to get the hubs locked in.
Sometimes almost took two people to get the hubs locked. One to bump the clutch a bit wile one turned to **** on the hub. Things have improved over the years in many ways.
Old Apr 16, 2021 | 08:15 AM
System's Avatar
System
Prolocutor
Let's keep er' on topic here boys... I cleaned up the rest...
