4r100 Knowledge please.
Old Apr 14, 2021 | 02:04 PM
Thatlostguy's Avatar
Thatlostguy
Hello everyone,
This is my first post here. Hoping someone can help me out or at least shed some light in my issue. So i drive a 00 expedition 5.4 with the 4r100. For as long as i can remember i could be driving down the highway at 70-80mph and hit the gas and at WOT it would down shift to about second gear and the RPMs would jump to 4000. But now if i go WOT on the highway it seems like it only drops to third gear and only about 3000-3500 RPM. Even if i turn overdrive off, it goes the third gear and then when i floor it it wont drop a gear.
Am i going crazy or is the transmission working fine?!?!?!?
Old Apr 15, 2021 | 12:29 PM
JWA's Avatar
JWA
There is a dedicated sub-forum for questions regarding transmissions---maybe post this there and hopefully you'll receive a few answers.
Good luck on this!
Old Apr 15, 2021 | 05:35 PM
85e150's Avatar
85e150
Post moved.
Welcome to FTE!
Usually the first step is to pull codes. Do you have a flashing CEL or OD light?
You need a way to read codes. Ford dealers and better transmission shops have the right code readers. Or you can find a way yourself, as explained in this thread, especially post 4.
https://www.ford-trucks.com/forums/1...l#post18974078
Old Apr 16, 2021 | 02:07 AM
udsuth78's Avatar
udsuth78
If you turn off orerdrive then the transmission is in 3rd gear. The 4r100 is a 4 speed with reverse , hence the 4r. How old are the plug/wires/coils? Fuel filter possibly due to be replaced?
99f350sd
Feb 1, 2023 04:51 AM
Fomoco1546
1983 - 2012 Ranger & B-Series
Oct 13, 2019 08:22 PM
Furian
Jun 7, 2018 06:30 AM
excoelis
2009 - 2014 F150
23
May 23, 2010 07:19 PM
Flame Out
Mar 25, 2008 10:58 AM
