5r55e second gear
Old Oct 13, 2019 | 10:50 AM
Fomoco1546's Avatar
Fomoco1546
5r55e second gear
After replacing the valve body gasket, low/reverse gasket, and the kit from Ford my engine braking has returned and works well.
When I plugged my obd2 scanner in I noticed most of the time my truck shifts 1-3-4-5. I have noticed 2nd gear, but rarely.
Is there a second gear or is it 1st gear in overdrive? Not sure what to check or should I try to reset the computer? Thanks
Old Oct 13, 2019 | 11:52 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That is the way they are programmed to shift. Second gear is first gear plus overdrive. With your right foot on the floor you should have second gear.
Old Oct 13, 2019 | 08:22 PM
Fomoco1546's Avatar
Fomoco1546
That's good to hear, I was afraid I have more problems. Thanks
mike_black
Jan 7, 2016 09:04 PM
Flame Out
Mar 25, 2008 10:58 AM
Jonboy1040
Oct 13, 2005 10:07 PM
txag
Jun 20, 2005 08:31 AM
