Just bought a dulley F350 and the thing had new parts golare put on it so I figured take a risk and know its not bulletproofed but with all the new parts which include new oil pump fuel filters oil filters valve covers ficm mod oil cooler fuel filters turbo tube fuel injectors in harness new sleeve glow plug mod trans filter shudder fix trans kits trans filters radiator flushed oil cooler oil change I mean everything and it ran hot today and was with no trailer and it has about 150 on it so what am I looking at a million bucks
Edit - post temperature numbers (coolant, oil, transmission fluid) so we know what you mean by running hot. Commas would help the original post, or put the new parts in a list form.
Quote "it ran hot today". Please post specific oil and coolant temperature numbers, just in case you are unaware 200 to 220 degrees F is the normal, correct coolant temperature for the 6.0, the difference between oil and coolant temp indicates the condition of the oil cooler. Good Luck, Russ
