Ford 9" Yoke
Old Apr 12, 2021 | 04:35 PM
68Flareside240's Avatar
68Flareside240
Ford 9" Yoke
Trying to find a yoke to fit my 77, and I am having a hard time trying to piece together what I need. Truck appears to have the short style 1310 yoke, with the bearing cap tabs. The only 1310 series yokes I can find in stock are the yukon with the end cap snap rings. I assume these will work, but is there a special U Bolt kit or cap that are supposed to mate with them to retain the outer snap ring? Here is the yoke style I am talking about. https://www.drivetrainamerica.com/n2...-u-bolt-style/
Old Apr 13, 2021 | 01:21 AM
77 HOS's Avatar
77 HOS
That flange is a u bolt style like the one you have no snap rings are used. It will have tab to hold the u joint in place. I'm in need of one too. I ordered thru bronco graveyard but they said will be a few weeks before they get it
Old Apr 13, 2021 | 05:50 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you tried these folks? https://www.ringpinionservice.com/
Or ? https://www.randysworldwide.com/ Ring & Pinion Sets - Randy's Gear Supply
Old Apr 13, 2021 | 08:26 AM
68Flareside240
Wasn't sure because every site I've seen them listed the picture just shows an outer groove for a snap ring and described it as a snap ring style. I had planned on ordering from them as I have about $75 worth of parts I need in their cart, just trying to get the total up to make shipping more reasonable. Literally the last part I need to finish up the rear end rebuild.
I have not checked into those suppliers but I will. Thanks for the heads up.
Old Apr 13, 2021 | 10:12 AM
68Flareside240
Called Yukon and spoke to a tech rep, the yoke PN YYF900601 does indeed have the locating tabs, though the stock pictures listed on most every vendors website does not show it. Thanks for the info gents.
Aireeek
Jun 8, 2011 08:58 AM
xjpilot
Apr 29, 2010 09:59 AM
84-250
Jun 28, 2009 11:13 AM
FARM69
Aug 9, 2004 12:59 PM
gingerbreadmaniac
Jul 17, 2003 01:03 AM
