Excursion Caster and Front End Pulling Right
Old Apr 12, 2021 | 04:25 PM
Smoothwater's Avatar
Smoothwater
Need some help getting the alignment dialed in on the Ex. Currently pulls to the right.
Think I may have a caster/camber adjustable bushing that maybe machined wrong.
Alignment Specs
LF / RF
Camber -.2 / -.3
Caster 5 / 2.8
Toe -.01 / 0
Thoughts on getting this corrected? Could you install a WFO shim on 1 side?
All new front end is installed along with new brakes and calipers.
Thanks!!
Old Apr 12, 2021 | 05:39 PM
Lance Helmert's Avatar
Lance Helmert
It just needs the correct bushing for the ball joint on the passenger side.
Old Apr 12, 2021 | 07:43 PM
Smoothwater
Thanks, has adjustable bushings on each side.
After getting some time to look at it this afternoon. Looks like they didn’t adjust the bushings at all. I had set the camber with a digital level. Set the toe and go I guess they were too busy to invest so time into it. Didn’t end up charging me. So on the search for another alignment place now.
johnmel59
Feb 26, 2015 03:41 PM
stirfrysteve
1983 - 2012 Ranger & B-Series
Sep 11, 2011 08:31 PM
firebug
Nov 18, 2008 10:26 AM
craziejoker
Sep 20, 2008 06:03 PM
