Front end alignments,augh!!!
Old Sep 20, 2008 | 02:44 PM
craziejoker's Avatar
craziejoker
Just curious, how often do you guys have to get one done?
I know 285/75/16s cooper stt and being a drw dont help, but every 15k?
Any input appreciated.
p.s
no bajaing,hardly any towing,and mostly highway miles
Old Sep 20, 2008 | 03:22 PM
BioHazrdMan's Avatar
BioHazrdMan
Shouldn't really need a front end alignment unless you hit a curb/big pot hole and knock it outa alignment. I have gone the life of the tires without a alignment just fine... no uneven wear or anything. I just don't let the wifey drive my truck and hit curbs!!! Usually get it aligned when buying new tires though...
Old Sep 20, 2008 | 05:46 PM
Pocket's Avatar
Pocket
I have a habit of getting alignments just to keep things right.... plus I take my truck offroad so I normally knock things out of whack at least once a year.
What I've recently learned is that almost all shops will just do nothing more than a simple toe alignment on our trucks. What happens is if the caster and camber are also off, then the toe alignment never seems just right, and you always need adjustments to the toe more often than normal.
Go to a really good alignment shop and have them check the caster and camber as well. If those need adjustment, it's going to be much more expensive. However, it will fix a lot of issues with driveability. Mine drives like a completely different truck after I had that done.
Old Sep 20, 2008 | 06:03 PM
ron's power stroke's Avatar
ron's power stroke
got my truck with 145k on it..now just turned 190k...never had front end aligned and my tire wear even all way around..I do rotate every 5 to 8,000 miles and i also run nitrous not air...
dramirez163
Michigan Chapter
Mar 15, 2014 03:24 PM
reevesky
Modular V10 (6.8l)
Jan 12, 2007 07:15 AM
Wooky71
1983 - 2012 Ranger & B-Series
May 18, 2006 08:11 AM
ExplorerSp0084
2004 - 2008 F150
32
Oct 3, 2004 07:54 AM
Jaysun285
1978 - 1996 Big Bronco
Feb 2, 2004 02:58 AM
