1965 F100 Front End Alignment - 1973 Front End -- Which Alignment Specs?
OK, so I'm nearing completion on the disk brake upgrade which was done utilizing the full front end change out from a 1973 front end. I plan to do a field alignment but will take it to the alignment shop later.
I'm assuming when I go to the alignment shop I should tell them to utilize the 1973 specifications, not the 1965 -- correct?
that was my initial thought however I don't know if the addition of disk brakes over the drum brakes changes anything in the alignment specs....
leonharu
08-20-2018 11:20 PM
stirfrysteve
1983 - 2012 Ranger & B-Series
09-11-2011 08:31 PM
