First 6.7
Old May 11, 2021 | 09:01 PM
  #46
cj45lc's Avatar
cj45lc
Got the high idle deal done today, used a 20k ohm resistor & AUX 3 switch which puts the idle at 1200 rpm when engaged
I had to buy a pack of 10 resistor so I have 9 left, if anyone needs one PM me & I'll put one in the mail
Old May 12, 2021 | 12:21 PM
  #47
mjs2011's Avatar
mjs2011
Originally Posted by cj45lc
I have kinda made a friend with the parts fella at Montrose Ford & thought he gave me a pretty good price for the yellow, he also quoted me a pretty good price on the LV trans fluid if I buy it by the box of 12. $77 and some change & they are only about 25 miles away from me & don't have to worry with shipping.
I ended up with about 1/2 gal of 50/50 mix out of the 5 gal I bought left. I had run tap water through 3 times, driving a short spell to reach op temp between each emptying. I was getting about 4 gal out with each drain from the primary & about 1 1/2 gal out of the sec. I then ran distilled water 2x the same way. When I last drained they both ran pretty clear. When I went to fill I figured there was close to 4 gal left in engine & heater & close to a gal in the sec. so I dumped 2 gal concentrate in the primary & about 3/4 gal in the sec then finished with a 50/50 mix. The trick to draining the sec is removing the hose off the bottom that runs to trans cooler (in case you didn't know), the drain petcock is in a helluva spot lol
You might want to check the freeze point of both systems to ensure you got back to a 50/50 mix. Based on your estimate of 4 gallons of water left in the system, and only adding 2 gallons of concentrate and topping off with 50/50, you will be well below a 50/50 mix overall, and run the risk of not having adequate freeze or boil protection.
Old May 12, 2021 | 07:25 PM
  #48
cj45lc's Avatar
cj45lc
I believe you are correct about adding the 2 gal of concentrate to my estimate of 4 gals left in the engine, must not have been 4 gal left because after running the truck a few days it read good to -30 on the anti-freeze tester I have. I don't remember what the boil-over read exactly but it was pretty close to the recommended protection.
Old Jun 9, 2021 | 10:26 PM
  #49
cj45lc's Avatar
cj45lc
Well I got the code for the DEF heater the day before I deleted my truck so I'd say the timing was pretty good. Replaced all 4 shocks & other than a front u-joint on the pass.side I believe I'm pretty much done with getting everything set so I have a good idea of what maint needs done & when. Enjoying the added fuel mileage from the delete so far & with the tune I have I haven't seen any soot from the exhaust pulling or empty.
Almost time for an oil change
__kurk__
18
May 7, 2020 03:59 PM
cjflyrod25
General Diesel Discussion
Oct 14, 2015 11:39 PM
bobkonaben
Jul 26, 2014 07:28 PM
bulletpruf
Dec 24, 2010 12:57 PM
boots6868
Apr 21, 2008 10:16 PM
