Carb spacer thickness.
Old Apr 12, 2021 | 03:03 AM
Kramercd's Avatar
Kramercd
I'm getting closer to to having everything I need to swap to a Clifford 2x4 intake. Got a set of EFI manifolds to go with it. Got one tear-drop air cleaner, looking for another. I think if I had to I could run it with the stock round air cleaner and have them both clear. Plan is to run a pair of Carter one barrels with the intake. Got some aluminum stock coming in to make the adapters. Do you guys think 1.5" is too thick? And would there be any benefit to adding spiral grooves to the underside of the adapter?
Old Apr 14, 2021 | 09:28 PM
The Frenchtown Flyer's Avatar
1.5 will work, but no better than a much thinner adapter.
Forget about spiral grooves. Snake oil "cure".
Old Apr 20, 2021 | 10:53 AM
Kramercd's Avatar
Kramercd
Would there be any benefit in trying to shape the adapter to make the path to the longer runners direct while "interfering" with the short path some?
Old Apr 20, 2021 | 04:43 PM
I'll suppose that there would be little-to-no benefit.
avellaneda13
Jul 12, 2017 02:26 PM
oleman
Nov 17, 2010 09:02 AM
6-2 GO
Nov 18, 2004 11:58 AM
modru2004
21
Dec 3, 2003 03:38 PM
RobbieC
May 30, 2001 05:21 PM
