460 FI Carb Manufold - Ford Truck Enthusiasts Forums
Old 11-15-2010, 04:38 PM
oleman
oleman is offline
oleman is starting off with a positive reputation.
Has anyone seen an intake manufold that will fit the 87-96 FI engine. Not a plate that adapts the air intake to a carb but a real intake manufold for a carb.
Old 11-16-2010, 10:27 AM
bigfordandjeep's Avatar
bigfordandjeep
bigfordandjeep is offline
bigfordandjeep is starting off with a positive reputation.
I think you need to swap heads to convert to a carb setup.
Old 11-16-2010, 10:30 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Diesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant futureDiesel_Brad has a brilliant future
What he said^^^ no one makes a manifold to convert to carb
Old 11-16-2010, 11:41 AM
mdula's Avatar
mdula
mdula is offline
mdula is starting off with a positive reputation.
There is a guy making an adapter plate for the EFI heads to bolt on a full carb Intake, like an RPM air gap or what not...It was posted somewhere on here a while back. This will allow you to use an older style carb intake with the efi heads...not that they flow all that well, but I'll see if I can find a link.
Old 11-16-2010, 11:43 AM
mdula's Avatar
mdula
mdula is offline
Old 11-16-2010, 11:51 AM
bigfordandjeep
you would be happier swapping out the heads and swapping in a 429 timing chain as well.
Old 11-17-2010, 10:02 AM
jokerforever's Avatar
jokerforever
jokerforever is offline
jokerforever is gaining momentum as a positive member of FTE.jokerforever is gaining momentum as a positive member of FTE.
Yeah, if you're set on using EFI heads with a carb then you have to use either the Price Motorsports carb adapter on an EFI intake or spacers to fit a carb intake.
There have been rumors floating around for a few years about a factory carb intake that was used with EFI heads. Supposable it was use in mid 87 on larger commercial applications (light duty dump trucks and over the road tractors, large irrigation pumps, etc). I've came across a couple of people on the web to claim they seen them/have them/could get them, and have even seen a post with a Ford part number, but I have never been able to confirm that they ever existed.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
