96 Explorer Radio Probs.
Old Oct 28, 2003 | 01:10 PM
Tourist's Avatar
Tourist
My radio turns on but no sound? The radio has been replaced and still no sound. Any help would be great.
Thanks
Old Oct 28, 2003 | 01:33 PM
SteveM's Avatar
SteveM
no sound?
if you are talking about factory radio no sound.
probably bad amp behind right rear panel.
could just be a fuse for it check fuses under hood also.
need more info .
Old Oct 28, 2003 | 01:35 PM
Tourist's Avatar
Tourist
Re: no sound?
need more info .
Yes it is the factory radio. The power turns on. I can change the stations. Everything is normal just no sound from the speakers.
Would you happen to know what fuse it would be?
Old Oct 28, 2003 | 02:14 PM
87 XLT's Avatar
87 XLT
I agree, take a look at the fuse page in your owners manual. My 95 Taurus has 2 radio fuses & 2 radio grounds. One ground is under the hood near driver side shock tower & one under the dash near the steering column.(yours might be different) Check the fuses & the grounds. An electrical trouble shooting manual from www.helminc.com would come in handy.
Old Oct 28, 2003 | 02:22 PM
SteveM's Avatar
SteveM
no sound
sorry. don't know which fuse.
if you have a test light dc. i turn on key, hook test light to good ground, then check each side of fuse for power.
if one side dose'nt light up pull fuse to see if it's blown in half.
check all fuses even under hood
Old Oct 28, 2003 | 02:51 PM
Tourist's Avatar
Tourist
All fuses look good so I am guessing it is the amp. Thanks for the help.
Old Oct 28, 2003 | 03:10 PM
SteveM's Avatar
SteveM
no sound
is explorer new to you? did it ever had sound?
is it an eddie beur-bad spell-?
on the back of radio did you have 2 large plugs?
1 grey 1 black or just 1 large black and 1 small plug look like
cord?
i'll try to help best i can, last you want to do is remove rear side panel. pain in but
Old Oct 28, 2003 | 03:15 PM
Tourist's Avatar
Tourist
Re: no sound
cord?
The Explorer is new to me. I know the last owner had the radio out and replaced it with another factory radio. Obviously this did not help the problem. I figured I could figure it out so he did not find out what the real problem was. It is not an edddie bauer.
Old Oct 28, 2003 | 03:30 PM
SteveM's Avatar
SteveM
pull it back out unless ya remember what those plugs look like
keep me posted
Old Nov 10, 2003 | 09:46 PM
Tourist's Avatar
Tourist
Fixed it!
Looked at the amp and one of the plugs was out!
Thanks for all the help guys!
Map Man 1
6.7L Power Stroke Diesel
Jun 20, 2014 01:39 PM
T2 HUFF
1978 - 1996 Big Bronco
Feb 2, 2014 01:03 AM
jcase321
Aug 28, 2006 09:34 AM
Douglas Krysiak
Oct 14, 2005 05:21 AM
lnmilner
Jan 26, 2005 08:45 PM
