Hi FTE my 2002 Excursion cluster is away at Circuit Board Medics getting repaired. While it's out I want to refresh the bulbs so I don't need to pull it back out anytime soon. I can't find what style bulbs it takes or where to buy them. Any advice? I found some stuff for earlier models but can't confirm if its the same for 2002+ with the later style cluster...
My 2001 Super Duty uses #74LL and # 194LL bulbs.... Would think its the same for you. Although I'd think they'd replace all those bulbs while repairing your cluster. The #194LL is the bulb for main cluster lights. Buy off Amazon or eBay... costs a lot less than your local parts store. Don't think they changed the cluster until 2004?
Gotcha! The 194 bulbs seem to be super common across the board so maybe they are the same for mine as yours. I think your 2001 cluster is a little different than mine at least in the position of the gauges, but that doesn't mean they used a different bulb. I think I'll order the 194LL units today.
This is the Ford sheets for Instrument Panel lights on my 2000 Excursion.
The one-off bulb in the middle with the white holder is Ford part # F7LZ-13B765-BA
This tread is a year old, I'm sure he's got it figured out by now.
Where'd you find that? I need to do some bulb replacement on my 03 F250 & the seller refused to give up the owner manual for some reason so I'm missing things like that & the fuse panel layout.
Went to local ford dealer's parts site and started with the automated chat feature, they asked for details and my email address. Local parts guy then emailed me those drawings so I could identify the correct bulb.
Thanks for pointing out the obvious, it was my intent to post relevant information to the Forum.
This information did not exist on this Forum or any other searchable website.
The next person that looks may actually find a useful answer here.
If that is not the purpose of the Forum, or if I have posted incorrectly, please explain.
