Another hpop gone
Another hpop gone
Went to Napa to buy oil. Went out to crank, 165 psi on oil. Truck ran great till...... Been waiting on tow truck since 12:30 pm.
I guess I'll get it home and do an air test to confirm. Pretty sure it's Hpop but will test to make sure. Already ordered through XPD. Next day delivery. They told me I could send it back if that's not the problem. Will have to pay shipping. Another day in the life of a 6.0 owner.
Late 2004 cylinder style hpop. Just put one in about a year or so ago. Like I mentioned above I'm gonna run an air test to confirm. It just makes ya mad when you get no warning. My hpop readings where steady 643 or 5 at idle. All my readings where great. When I fired it up cold and at autozone, fired Wright up in about 1. 2 seconds. Hit Napa for ec coolant and rotella oil and no joy when I went to crank. Dummy plugs and pipes have already been done. So we'll see.
Well I guess I can almost count out hpop. Went out to start work, and for Chitsp and giggles I tried to start. It started Wright up. Took it out and got here up to temps and parked her to try and start. No luck. Cancelled hpop for now. I'll go out in the morning and do the air test I was gonna do today. Any idea's? Checked oil, seemed a little thin. I guess I could change oil and see if that helps. But it hasn't been no 10000 miles since my last change. Dummy plus and pipes have been done. 125000 miles doesn't seem like it would be injector problems. I guess I'll just start from beginning in the morning.
Another customer with a 2004 F350 came to me because it continually stalled when hot. You had to wait till the truck cooled off enough to start. Swapped the IPR with a known good IPR and it never stalled again.
Very true. Diesel nailed it.
I got off easy. Went in and removed air assembly, degas and Ficm. Turbo crossover heat shield. Unhooked 6 and 8 injector connections, Ficm ground and intake bolt. Slide socket on. That's where it got tricky. Needed more umf to break loose. Breaker bar 3/8" end didn't line up to work. So I put wrachet back on and took a 3/4" property iron and slide on to break ipr loose. (Got Lucky) unhooked pigtail.
I was ready with test fitting, when I started looking at ipr. I hate to say it, but when I seen a deteriorated o-ring and spacer I was happy. Had one in tool box. Put it together. Bam.
Only thing makes me worry is I couldn't find or dig out any of the old oring or spacer. Looked in there with scope but didn't see anything that jumped out so I reinstalled. Truck runs great.
2.5 hrs of my time versus $1000.00 shop bill.
I'm trying to confirm health of the HPOP (see my thread here) but I'm not very familiar with these (to say not at all) and am concerned about putting it back together and ruining a perfectly good IPR valve. Any words of advice for a 6.0L noob? Thanks
copied from your other thread:
Check for air leaking also at the CCV location (on the driver's side valve cover).
If there is no leak on the driver's side, then it may very well be only a dummy plug on the passenger side.
A hole in the IPR screen might mean that there is trash in the IPR that would hold it open. If there is nothing preventing the IPR valve from closing, then a hole in the screen would not cause a leak in the high pressure system. Neither would trash clogging up the screen (until the pressure pushed it through the screen and caused it to stick the IPR valve in the partially open position).
Guys, Mark is correct on the above posts. A busted screen is not going to couse lack of pressure in your system. Stuck open IPR, yes. My issue was with a broke o-ring, witch when oil got hot it just flowed bye and didn't build pressure.
With the air test, take Marks advice with listening on all sides. Both ccv on driver and oil fill on passenger side. A bad Dummyplug is a whole lot easier than an Hpop. (and cheaper) If it is gurgling under oil filter housing after you eliminate dummyplugs and standpipes, good possibility that your hpop is toast. Good diagnostics can save you a lot of money. These guys are good, take heed in what they say.
