Help with headers
Old Apr 9, 2021 | 10:05 AM
Thedonz4x4's Avatar
Thedonz4x4
Help with headers
Hi All,
I have a 1987 F-150 5.0, auto, 4x4 that i am taking out the engine to replace head gaskets and re-surface the heads, replace the main seal and replace the flex plate. I need to replace the exhaust manifolds as one is cracked. The bolts are frozen so I am going to cut the pipes and take out the engine.
I am thinking about going with a set of headers instead of cast manifolds. I have the following questions:
1. Should I go with headers rather than manifolds? Pros/cons?
2. If I go with headers, what do you all recommend from experience as far as brand and style (shortie vs. long tubes)?
3. How can I identify what auto transmission I have?
4. Without going inside of the block, are there any upgrades, mods I can do to get a bit more power out of the engine? For example, If I have the machine shop shave the heads a bit more than simply resurface, can I increase the compression enough to make any difference? Is there a more efficient air intake system that makes a difference. I am already thinking about new exhaust without cats and more efficient mufflers.
Thanks for your help.
Old Apr 9, 2021 | 01:22 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Duplicate thread:
https://www.ford-trucks.com/forums/1...h-headers.html
cmklmep
Modular V10 (6.8l)
Sep 12, 2019 09:34 AM
Submarriner
Feb 11, 2014 09:22 PM
supercabfreak
16
Jan 16, 2011 09:42 AM
MR DSL
1997 - 2003 F150
Jul 27, 2010 09:36 AM
PROSTOCK
22
Oct 4, 2004 04:38 PM
