75 F250 won’t start .
Old Apr 7, 2021 | 09:03 AM
Hemet2020's Avatar
Hemet2020
4wd Low
Hi all, my truck won’t start till I hook up jumper cables & another battery. The battery was fully charged . I saw a post on checking your system with a 12 volt test light but can’t find it now. Cleaned cable grounds , but when I got to the regulator I got 12 volts at the grounding screw, is that right I don’t think so. It was getting dark & I just got done installing a carb & r&r all four tires with new rims & tires . She has been sitting for years, any input will be appreciated. Thanks
Old Apr 7, 2021 | 09:08 AM
440 sixpack's Avatar
440 sixpack
First thing to do is see if it has spark.
Old Apr 8, 2021 | 10:02 AM
CelticOne's Avatar
CelticOne
Regular User
Welcome to FTE!
So you are saying it will start with a boost but not on its own?
Old Apr 8, 2021 | 11:41 AM
Hemet2020's Avatar
Hemet2020
4wd Low
75 F250 won’t start
Yes when I jump it it starts. The battery in it is good ???
Old Apr 8, 2021 | 11:52 AM
redroad's Avatar
redroad
If she's been sitting for years your going to want to replace all the rubber fuel line and hose clamps for good measure. Start the motor off a can of clean fuel before you get any of what's in the old fuel tank in your carburator and then have a real mess on your hands.
Before you let her fire disconnect the coil wire and let her turn over several long bursts to properly lube her since she's sat so long. Reconnect the coil and wake her up.
Old Apr 8, 2021 | 12:16 PM
Hemet2020's Avatar
Hemet2020
4wd Low
Yeah I put some atf in each cylinder & let it sit for a couple of day & installed a fire ready to happen electric fuel pump to a 5 gallon can & it fired off beautifully. It’s a 390 that had less than 1k miles on a recent rebuild before parking it . Since then I hooked up original fuel system I installed 2 inline fuel filters between tank & fuel pump & changed fuel pump Filter & carburetor filter. I just installed a rebuilt 2 barrel carb & new 17 rims & tires. I’m falling in love with the truck all over again. The truck needs work but I’m retired now & it’s my mission to get it up & turn key solid. The not starting with out a jump has got me stumped, I clean grounds , pulled alternator, everything looks good .
Old Apr 8, 2021 | 12:41 PM
redroad's Avatar
redroad
Personally, I think during these times working on an old Ford truck sounds about perfect, IMHO of course.
Have a look here for electrical trouble shooting.
Old Apr 8, 2021 | 01:34 PM
JRKMotorZ's Avatar
JRKMotorZ
I had issues in the past where the starter needs a rebuild because it draws too much amperage. I had to jump start my fully charged battery in order for it to fire up.
2011 f 350
Jun 26, 2020 05:35 PM
patshea814
Nov 3, 2010 08:55 PM
1992F250
Aug 19, 2006 06:12 PM
BHBA12857
Jul 28, 2005 09:28 PM
howefiretr
Jan 28, 2002 07:09 PM
