Ford truck information and then some.... - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 09-27-2014, 10:37 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Rich's "rep o meter" is gonna go bonkers.
Awesome post and many thanks.
Grin
  #47
Old 09-28-2014, 06:36 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Rich...
Ask a moderator to place this thread as a STICKY .. Otherwise it won't be long before the pages are buried with the other old threads.
FYI: 1973/79 Ford Light Truck Parts Catalog available on a C/D from hipoparts.com
  #48
Old 09-28-2014, 08:54 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Grin
And it should.
  #49
Old 10-01-2014, 08:34 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Ok thanks to the mods its stickied...and once I get 8 diagrams saved up, I will keep on posting.
Pass the word, copy and paste the link.
  #50
Old 10-01-2014, 09:28 PM
KIKKUP's Avatar
KIKKUP
KIKKUP is offline
KIKKUP is gaining momentum as a positive member of FTE.KIKKUP is gaining momentum as a positive member of FTE.
Wow, just decided to browse the stickies today and see that someone has been very busy! Excellent work Rich!
  #51
Old 10-08-2014, 11:01 AM
Beedub109r's Avatar
Beedub109r
Beedub109r is offline
Beedub109r is gaining momentum as a positive member of FTE.Beedub109r is gaining momentum as a positive member of FTE.
Thanks Rich
Thanks for putting this together. Your insight and posted diagrams are a big help. Before I get on the forum and ask a question, I scroll though this sticky. Great work and thanks from all of us for your help.
  #52
Old 10-11-2014, 07:57 PM
txacoach's Avatar
txacoach
txacoach is offline
txacoach is starting off with a positive reputation.
Originally Posted by 77&79F250 View Post
use Rustoleum Industrial Aluminum spray paint, comes in a 33% more can. Used less than half can to do inner fenders for around $12 a can, the primer is about $8. It dries really fast, goes on thick, and never gets runs. I used Rustoleum Industrial spray paint for everything. I have painted all kinds of things like the fire walls on a 68 cougar xr7, 1956 ford, 1955 ford Crown Victoria, numerous parts, and a whole van for a friend.
It goes on really good with one coat, lots of coverage, 2nd coat has to be within an hour, or after 48 or something, I just do 1 coat. I tried other spray paint, but this is my favorite, for a rattle can job anyways. It's enamel, so it takes long time to cure. It does dull, and in a year I do expect to see rust coming out again, From Acklands Grainger.
Cowl painting advice:
Poly is not the same as epoxy. You need to lay down an epoxy primer over the areas of bare metal, let dry, give a light scuff then you can either lay down a poly surfacer ( high build) over the whole truck to fill any imperfections then block smooth and then spray primer sealer over the high build, block smooth then top coat or you can skip the poly surfacer and just go directly to sealer over the epoxy if you think your body work is good enough. Then top coat.
Ever seen a 77 grill on a 78/79 Bronco, it will fit just to be different.
SD rear seat in a 79
Hey,
What year SD is this seat out of? I am digging the look.
  #53
Old 10-11-2014, 09:13 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
2001 according to what I have read in the fellow FTE members thread that did it.
Do a thread search for a Arkansas member with a white 76/77 (?) 4x4 F250 that also did an awesome job with a headlight upgrade, its his truck thread I got the info from.
  #54
Old 10-12-2014, 02:25 PM
Stephen Dazey's Avatar
Stephen Dazey
Stephen Dazey is offline
Stephen Dazey is starting off with a positive reputation.
https://www.ford-trucks.com/forums/1...-build-16.html
I think this is what Rich is talking about - hope it helps
  #55
Old 10-15-2014, 10:31 AM
stehr
stehr is offline
stehr is starting off with a positive reputation.
I just got a 79 f250 4x4 w/ factory a/c has a 400 and auto trans, camper special. It appears to be pretty much factory original, right down to the radio. It has 2 rectangular plastic reservoir tanks on the outside of the frame under the passenger door with mounts welded to frame. 1 has 2 rubber hoses to it but they were cut/broken off so I can't see where they go. They have no fluid in them. Any idea what they are? Thanks.
Sorry I should have taken pictures before I came to work.
  #56
Old 10-15-2014, 12:02 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Welcome to FTE, this thread is a "information thread only" and not the best place to ask questions, thanks for understanding.
No worries, I know you are new. So just make up a new thread (new thread box top left side of the 73-79 forum)and post the question there. That way your question will be seen my many more FTE members.
Camper Special...outside the frame, no probably NOT gas tanks, maybe old water storage tanks if they are large. I bet they are white and small (6x8 ish?) and are part of the old emission charcoal filter system?
I remove the set off my old 79 4x4 F250 351M 4spd.
  #57
Old 10-17-2014, 08:34 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Here is some more good stuff IMO.
1st pic is page 3 of the dealer installed a/c, a few pages back are pg 1 & 2 that go with it.
Hay folks copy and past this as a link and pass the word to fellow FTE folks. I suggest to copy and past the word text in a word doc and the pics onto your computer, that way you do not have to have the web to look at it.
Copy this and paste it to help out.
https://www.ford-trucks.com/forums/1...then-some.html
  #58
Old 10-22-2014, 05:39 PM
Sooper Camper
Sooper Camper is offline
Sooper Camper is starting off with a positive reputation.
awesome thread, keep up the good work!
  #59
Old 10-26-2014, 05:09 AM
smalls7676
smalls7676 is offline
smalls7676 is starting off with a positive reputation.
hey man thanks a bunch this stuff will help a lot
  #60
Old 10-28-2014, 11:22 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
New IM (Ignition Module) information:
Ignition modules, 74 (black grommet) and 75 (green grommet) are year specific and will not interchange. 76 to 79 (blue grommet) are interchangeable.
Ignition modules: 1974 is 1974 ONLY / 1975 is 1975 ONLY.
Blue module introduced in 1976 was used well into the 1990's.
D4AZ-12A199-C 1974 only
DuraSpark ignition modules identified by a colored plastic insert located above where the wires feed out.
2 others: One has a red plastic insert, the other has a yellow or brown plastic insert.
Red module is D7AZ-12A199-A used in some CA vehicles ONLY.
D9AZ-12A199-C (replaced D8AZ-12A199-A). One of these modules is yellow, one is brown. Since the part number was replaced, I (ND) cannot recall which module was which color.
These modules were used in 1978/79 302 & 351M/W vehicles sold in high altitudes only. 351W: Passenger Cars & Econolines only.
1U2Z-12A199-AA (replaced D6AZ-12A199-B - D7AZ-12A199-B - D8VZ-12A199-A - D9VZ-12A199-A) .. Ignition Module - blue insert (Motorcraft DY-893) / Available from Ford.
Myriad 1976/90's FoMoCo vehicles.
Green Sales in OH.
Collectors Auto Supply in WA.
Haven Ford in KS.
Klimesh Motor Sales in IA.
Bob Allen Ford in KS.
Freese Motor Inc in IA.
Wesley Obsolete Parts in KY.
Dennis Carpenter Ford in NC.
Quick Reply: Ford truck information and then some....
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
