Decipher Rear Ford Diff Tag
Old Apr 6, 2021 | 03:56 PM
asterof's Avatar
asterof
2001 Ford F150 4 x 4 5.4l
Top Line: S 942 A
Bottom Line: 55 9 75 1A02
I assume this is a 9 inch ring gear ? but I dont know
Could not find one online that matched the number pattern
Old Apr 6, 2021 | 07:01 PM
brokenleg's Avatar
brokenleg
5.4 trucks have the 9 3/4 rear end. And there is 3 ratios. 3.08s, and 3.55s. 3.73s will be on 7700s.
Does your truck have the off Road package? If so it will have 3.55s.
Old Apr 6, 2021 | 07:19 PM
gDMJoe's Avatar
gDMJoe
Exclamation
asterof ...
*heads-up* You've posted in the 2009 - 2014 F150 forum.
Old Apr 7, 2021 | 05:18 AM
asterof's Avatar
asterof
Opps wrong forum Sorry
Old Apr 7, 2021 | 05:21 AM
asterof's Avatar
asterof
Thanks
as the tag says 55 I assume its a 3.55 cause it has the off road package
Old Apr 7, 2021 | 05:51 AM
Siberexpress's Avatar
Siberexpress
If it is the stock rear end look at the door tag but from the bottom line it appears to be a 3.55 and it is a 9.75 weather it has the 19 or H9 on the door tag is whether it is limited slip or not.
19 – 3.55 Non-LS
18 – 3.08 Non-LS
H9 – 3.55 LS
B6 – 3.73 LS
Old Apr 7, 2021 | 08:05 AM
projectSHO89's Avatar
projectSHO89
You have the 3.55, open differential, 9.75" based on what you have provided.
The "3" is probably covered by the bolt head.
If it were an LS axle, the bottom row would read "3L55" as the first characters. It may be possible that the "L" is also under the bolt head so you may need to pull the tag off for a closer look.
Old Apr 7, 2021 | 11:36 AM
asterof's Avatar
asterof
maybe this will help
String is holding gear in place to be sure it does not fall out. Replacing axle bearings is the reason so I can get the right bearings the first time
Green Griffin 420
18
Sep 27, 2023 12:40 PM
Super Duty Diablo
Feb 16, 2014 09:11 AM
cookieman69
18
Dec 26, 2009 10:57 PM
Southpaw2
1997 - 2003 F150
Apr 11, 2005 10:42 PM
tomrooster-1
Mar 17, 2005 10:30 PM
