F250 Clockspring
Old Apr 3, 2021 | 09:15 PM
CatD2's Avatar
CatD2
F250 Clockspring
I recently purchased a 2001 F250, which I knew when I made the purchase that the horn didn't work. While driving it home, I noticed the cruise control didn't work, and also that the airbag light would come on, and periodically go off. After researching this on this site, I determined the problem is likely the clock spring. This truck has a 7.3 and has 275k miles. I did change the fuse in the horn and the horn worked, but I didn't have the truck running, nor did I turn the steering wheel. I removed the steering wheel to get the part number on the clock spring, which is F81A-14A664-CE. While checking on RockAuto and a few other sites, I didn't see any of the clock springs with that part number, and when I searched on that number, only came up with one listing, which showed this associated with a 5.4 engine. The part that I ordered 1L3Z-14A664-AA. I have two questions, 1) does it appear my problem is the clock spring, and 2) should I be ok with the part that I ordered? Thanks.
Old Apr 4, 2021 | 07:54 AM
Listor's Avatar
Listor
found this, it lists the f 350 and vans, gas and diesel
https://www.tascaparts.com/oem-parts...RoCw8UQAvD_BwE
seems your number is basically the same should work
Old Apr 4, 2021 | 11:07 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
A while back I performed a bit of research on the various clock spring options, which may be of some benefit to you.
https://www.ford-trucks.com/forums/1...re-spring.html
zarmo
Sep 16, 2016 08:33 AM
kodabear
Sep 12, 2016 12:28 PM
aaronlaaron
Sep 8, 2015 04:21 PM
LoyBaird
1997 - 2003 F150
Apr 6, 2014 09:35 PM
gunner9821
Electrical Systems/Wiring
Mar 3, 2004 07:09 PM
