Engine tap
Old Apr 3, 2021 | 08:24 AM
daveinva's Avatar
daveinva
Engine tap
Hi gang, when I crank my 360FE when cold, occasionally I hear a tap. If I shut the engine right off and start it again the tap is gone. It only does this when cold. So, I must be catching something on either up or down stroke. Is this a telltale sign of a bad lifter, something out of adjustment, or something else totally?
Old Apr 3, 2021 | 08:35 AM
440 sixpack's Avatar
440 sixpack
Probably a lifter but it doesn't have to be. if it gets bad enough to worry about you'll know it.
Old Apr 3, 2021 | 08:47 AM
NM76F150's Avatar
NM76F150
My 351M did that. Added 1/2 quart of Marvel Mystery oil and it never did it again.
Old Apr 3, 2021 | 09:55 PM
jakeharp's Avatar
jakeharp
Just my opinion, specially on an FE, if thats all you got, drive your tuck and count your blessings, make sure your using a Zinc additive with your oil, use a heavy oil and roll on...
Melonmuziq
21
Oct 16, 2019 04:21 PM
daveinva
Aug 11, 2019 09:13 AM
Ncrisalli9
2015 - 2020 F150
Jul 9, 2018 01:15 PM
MrKen
Aerostar
Nov 11, 2010 04:08 AM
Traxxis
1983 - 2012 Ranger & B-Series
Mar 9, 2004 07:40 PM
