Sponsored by: Auxito
Rattle
Old Mar 31, 2021 | 06:23 AM
Sabrina Ragan's Avatar
Sabrina Ragan
Rattle
So I have a ratttle under the hood someone said its a pulley and it sounds kinda like the heat shield but I’m not sure how I go about finding out what it is for sure besides paying some high dollar person to figure it out 2000 f150 5.4 triton
Old Mar 31, 2021 | 08:46 AM
Stonedpony's Avatar
Stonedpony
Talking
To check a pully, just remove the serpentine belt and crank the engine and see if the sound goes away. You can run the engine long enough without the belt to hear if it has. (About 2-3 mins tops and not longer)
Remove serpentine belt by taking 1/2 drive ratchet or 3/8 drive depending on which one you have. (Look down from the top about the middle ways of the engine and you will see it). Placing it into the notch of the pully tensioner (A little square-looking hole on the side facing you with a pully on the backside) made for this and pulling tensioner to the left to let the belt get loose and remove the belt. (Take a picture of the belt to see how the belt goes on and is routed if the old diagram is no longer on the front of the truck).
Now with the belt off before you crank the engine, take each pully on the front of the truck and spin them by hand to see if you hear a rattle or whine. Make sure to spin all the pulleys that the belt goes around even the water pump (the fan is attached to), AC pully, and power steering. If all of these are good, go under the truck and look at the heat shields around the exhaust pipes and see if they are against anything and do not have broken bolts or anything like that.
Not that hard to check and see.
In God, I trust all others pay cash. You can send the high dollars to check to BAR549 and remember all sales are final here.
roller_steve
17
Jul 25, 2008 12:11 PM
pipesalesman
Feb 6, 2007 01:28 PM
Baumer
Jun 20, 2006 03:20 PM
FORD 4 ME
2004 - 2008 F150
Nov 2, 2004 10:33 AM
kk
Oct 16, 2002 05:07 AM
