Replacing all tie rod ends, tips or tricks?
Old Mar 30, 2021 | 08:31 PM
BigJC's Avatar
BigJC
I plan to replace all 4 tie rod ends on my van this weekend. 2011 E-150, and will replace with moog everything.
Can I do this without changing toe/alignment or is that not possible?
I was planning on duplicating the old and measuring from center of grease fitting to center of grease fitting both left and right. I also plan to sharpie my rims and pull a precise of a toe measurement as possible. With this I'm wondering if it's worth the trouble of precisely duplicating the old linkage or just leave my adjusting sleeves slack and focus on the toe measurement.
Any tips or tricks?
Old Mar 31, 2021 | 04:32 AM
JWA's Avatar
JWA
You'll not achieve precise toe setting by any method other than an alignment rack. There are those who do achieve adequate for them results but doing that much work without verifying the results isn't the best approach. Tire wear would be a big concern but since this is your vehicle do as you feel is best or the budget allows.
Another benefit to finding a competent alignment mechanic is the can inspect the entire steering system and advise if the ball joints etc need attention.
Good luck!
Old Mar 31, 2021 | 09:55 AM
BigJC's Avatar
BigJC
Thanks JWA. I'll plan on an alignment as soon as possible afterwards.
Old Mar 31, 2021 | 04:06 PM
muhford's Avatar
muhford
If you're going to do tie rods you might as well change the track bar too.
Old Mar 31, 2021 | 04:20 PM
BigJC's Avatar
BigJC
The "drag link"?
I'll be replacing everything in between the pitman arm to the spindle. Hope I'm covered there, on Rockauto they're listed as inner/outer, left/right tie rod ends. There's another listing for the drag link but it's identical to one of the inner tie rods.
I've already done all 4 ball joints which frankly was much less challenging than I had anticipated.
Hopefully this gets rid of a front end clunk I've had since owning the van 30k ago. Regardless it shimmies a bit in turns and all tie rods are easy to rotate back and forth by hand. No real 2-3 o'clock play though or back and forth movement in the linkage. There is a bit of slop in the steering though.
Old Mar 31, 2021 | 04:24 PM
muhford's Avatar
muhford
Originally Posted by BigJC
The "drag link"?
Nevermind. I was thinking this was 4x4 for some reason. Silly me
Old Mar 31, 2021 | 07:01 PM
Spaznaut's Avatar
Spaznaut
Do you know if your alignment is good now? You would have to have a good starting point to be able to match up and be close.
Old Mar 31, 2021 | 09:37 PM
BigJC's Avatar
BigJC
It's in spec now to my knowledge. I had an alignment after I changed the ball joints and got new tires, Cooper AT3. I definitely do not want to kill my tires as they probably have 30k left on them.
Pridnjoy
Sep 29, 2015 04:41 PM
countryboy73703
6.4L Power Stroke Diesel
13
Sep 12, 2013 09:31 AM
cordespc
1997 - 2003 F150
Apr 28, 2007 09:17 PM
East Side
1983 - 2012 Ranger & B-Series
May 10, 2003 06:19 PM
oldblue18
Jul 15, 2002 12:32 PM
