Speedometer vs. odometer accuracy
Old Mar 30, 2021 | 07:10 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Howdy all
I've determined the speedometer is about 5 mph low at 55 or 10% low. Does that mean the odometer will be 10% low too?
Old Mar 30, 2021 | 07:24 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Most likely, yes. Check it against the mile markers on the freeway. 10% should be easy to measure, it will be off by a mile in a 10 mile trip.
Old Mar 30, 2021 | 07:32 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
That's what I hoped. I'll check to be sure, but if so, my mileage just went from 13 to 14.3 mixed driving..
Yipeee!
Old Mar 31, 2021 | 03:56 PM
scottscott's Avatar
scottscott
Not necessarily,
The odometer is directly driven off of the speedo cable, which is directly driven off of the transmission.
The speedo is not directly driven thru the cable. The speedo relies on a magnet that is driven by the speedo cable. The magnet revolves around a disc, the disc is not directly attached to the cable or magnet. As the magnet revolves around the disc, it moves the disc, & the needle. The faster the magnet moves, the further the disc moves. But, if the magnet is weak, or if the bearings for the disc & needle are worn or lacking lube, it is possible for the needle to not move as far as it should. And in that case the speedo would read slow, or may not work at all. So, the odometer would read one way, the speedo would read another. I hope this makes sense.
I've tested dozens of speedo & odometers, I use a 1000 RPM drill to spin them. Most speedo's are designed to read 60 MPH at 1000 RPM, most do, but some are + or - 5 MPH. Usually 5 MPH or so slow.
Old Mar 31, 2021 | 09:09 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Thanks Scott. I calibrated the odometer over a 10 and 25 mile stretch of highway. It is 18-19% low (10 on the meter is 11.8+ on the mile posts). Recalculating the old mileage and today's calculation yields about 14 mixed driving.
Now to fix rotten bed floor so the tailgate stops acting like a drogue chute.
Old Apr 1, 2021 | 04:17 PM
scottscott's Avatar
scottscott
19% is a big error. Pull the driven gear at the end of the speedo cable & count the teeth. To correct the reading, you need a gear with 19% few teeth. That number will probably be 3 or 4 fewer teeth. If that tooth count gear isn't available, the driven gear in the transmission would have to be changed.
If the tire size is different from stock the speedo & odo will be off too.
Old Apr 2, 2021 | 02:10 AM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
I'm running 21575R15 (27 or 28" diameter) tires which I believe are stock size. I have not counted the teeth on the speedo. The gears I have found range from 16 to 21 teeth. If the current gear is 20 or 21 teeth, a 16 or 17 could solve the error.
Old Apr 2, 2021 | 10:50 PM
jason832's Avatar
jason832
To check the accuracy of the speedometer just download a speedometer app for your phone. They run off GPS and are something like within 0.1mph accurate when driving at a steady speed. I assume the odometer in app are pretty accurate as well.
Old Apr 2, 2021 | 11:39 PM
kr98664's Avatar
kr98664
Originally Posted by jason832
To check the accuracy of the speedometer...
Find a local speedtrap. Here’s a database you can search:
https://www.speedtrap.org/
Drive through the speedtrap at a steady velocity, maybe 20MPH or so over the posted limit. Compare your speedometer reading to the number printed on your ticket. Repeat as often as desired.
6t6merc
Jan 17, 2016 09:12 PM
52 F1 Stocker
Oct 21, 2015 08:20 AM
bankert8806
May 14, 2013 07:25 PM
alconk
Apr 18, 2009 11:33 PM
Bogaski
16
Dec 12, 2001 02:00 PM
