T98 - 1R 9W
Old Mar 30, 2021 | 02:18 PM
kryahlstrom's Avatar
kryahlstrom
4wd High
T98 - 1R 9W
T98 - 1R 9w bolt hole 8 1/2" across top holes c-c 4 3/4 lower R from top R 2 3/4 lower L from top L 8 3/4 across lower holes c-c
Hi everyone, brand new to this site. Like everyone else who has a T, I want to replace with a T98. Have one listed in the title. Problem is the input shaft is 1 &1/4" longer than the T8 shaft at 6" so the stock bell depth of 6" can't take the T98. Plus the bolt pattern of the T98 can't work with the T9 bell half. To member "Number Dummy" as well as the rest: What bell or combination must I have to mate to my 239 flathead v8? Thank you!
Last edited by kryahlstrom; Mar 30, 2021 at 02:36 PM. Reason: wrong info / additional photo
Old Mar 30, 2021 | 04:28 PM
abe's Avatar
abe
Kryahl, welcome to FTE the best Ford truck forum on the World wide Web!
I can't help you but more knowledgeable guys will be here to help you. In the mean time show us pictures of your truck and it's history.
Old Mar 30, 2021 | 05:46 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Welcome to the forum! The 1-1/4" longer input shaft is just about what '53-on trucks used, can you post a picture of the tailshaft / rear mount?
Old Mar 30, 2021 | 07:05 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
You will want to look through this thread as you probably have a later T98 that will not directly fit in the 48-52 trucks.
https://www.ford-trucks.com/forums/1...rrect-t98.html
If you look there, it seems yours matches one of my examples that seem to be what would be found starting in '53.
Old Mar 30, 2021 | 09:40 PM
1952henry's Avatar
1952henry
The correct T98 would have the same bolt pattern as the T9, if I'm not mistaken. The pictured T98 has ears for external mounting. Probably noted in the above link.
Old Apr 1, 2021 | 10:52 AM
kryahlstrom
4wd High
Bmoran4 , what a great link you provided! thank you. Now I know what I'm supposed to get - the Synchro-Silent. I don't know how you guys keep track of threads.. maybe I'll get it figured out. So my T98 is from a Y block as identified.... any one need it? and any chance there is a Synchro-Silent with the driveshaft park brake sitting in one of your shop or behind the shop? I can't figure how to get photo of my f2 next to my handle as so many of you have.
Kerry
JohnNewb
Apr 23, 2020 08:42 PM
50f6
Feb 10, 2016 05:53 PM
44nneedit
Dec 18, 2015 03:34 PM
Morty911
Mar 13, 2015 07:48 PM
79 posi
Apr 13, 2003 07:00 PM
