What does all this mean?
Old Apr 1, 2021 | 05:42 AM
  #31
Germanrazor's Avatar
Germanrazor
Like I said, maybe that is how their report reads and prints out. It is misleading and not easily interpreted if that is so. They should come out with a format that shows your initial readings, what they should be in a range value, then your final adjusted readings as they relate to the specified value range they should be in.
But once again, logic evades some of these program writers.
Old Apr 1, 2021 | 06:07 AM
  #32
Smindustries's Avatar
Smindustries
That report is extremely easy to read. I cannot comprehend your position that it's misleading and not easily interpreted. The only way to misinterpret that report is not know where numbers fall on a number line that starts with negative values. Furthermore, they color-coded it. When values are out of spec, they print red. When they're within spec, they print green. There's no way to misinterpret that report.
Old Apr 1, 2021 | 06:16 AM
  #33
Smindustries
No it wasn’t according to the values.....maybe you need glasses my friend!
Clearly you don't know how negative integers work. Let me teach you:
Front left camber was -0.3º before. The specified range is -0.6 through +0.9 degrees. A number line works as follows:
-0.6, -0.5, -0.4, -0.3, -0.2, -0.1, 0, +0.1, +0.2, +0.3, +0.4, +0.5, +0.6, +0.7, +0.8, +0.9
Note that -0.3º falls within range. Now apply your new skill to all the values on that report and realize you didn't remember elementary mathematics.
golfmedik
6.7L Power Stroke Diesel
16
Aug 5, 2017 08:01 PM
jeffreyclay
Aug 13, 2016 10:04 PM
MikefromMT
Sep 6, 2012 09:23 PM
craziejoker
Sep 20, 2008 06:03 PM
GreatNorthWoods
26
Mar 22, 2006 12:00 PM
