If you look at specified range and then your actual readings of what your truck is, appears to be out of the specified range on a few points. I read that printout just like I would a blood panel work up where it tells you your actual readings then what range they should fall in. Like I said, it could be just the way it is written by that program and I am off base. But it appears a few areas are not within range.
Everything was within range, both before and after.
Maybe you should stop reading blood panel work-ups.
By the looks of that there was no bushings installed, it's very low.
I'm just going off of what he said in his first post. Said he did all the suspension work including Carli caster shims. Maybe it wasn't "he" that actually did it🤷🏻♂️. Maybe he'll come and confirm that soon.
I'm thinking it might have been in that range to begin with(stock), and after the 2.5" lift 2 degree shims just put it right back there.
I guess he could use what some others have used, 2.3 and 2.6 degree to get a little more out of it.
The way I read it is everything is fine according to specs.
If the steering wheel is in the correct position, then I would agree with maybe a bit more caster, but clearly that is not needed either.
Just watch the tires and if you detect anything then take it in.
As far as centered? I did that when I did the level/bushings.Why would we recommend more caster if it is in spec?Just asking because I don't really understand all the nuances.The tires seem to be wearing OK.
I do see now that the camber and toe are a little low of the specified range.Is this what you are referencing?How much affect would this actually have on the steering/tires?
Nvmnd..I see that they are both in range...I never was good at math.See this is why I posted here,I'm learning.
Reason: I suck at math
I did in fact do all this work myself.The bushings I installed were the one that seemed to be the favorites here.
Having more caster increases tracking stability and reduces the potential of death wobble. Many people will intentionally set it at the most positive end of the range, or even over.
Good to know..thanks.Again,this is why I threw this out here.
Valid question!
All these numbers can be foreign to those who haven't worked with them.
Think of caster is as the fork angle on a bike or motorcycle. If the fork was straight up and down, it would have the stability of a shopping cart wheel (visualize that, if you will). But on the other side, you have a chopper with very slack steering. At speed, it can be very stable, though it won't handle so well at low speeds. Of course, the goal is to find the middle. Before the days of power steering, you didn't want much caster because it made it harder to turn at low speeds. But with power steering, it's ok to have more caster. I am over simplifying this for the sake of visualization, but that's the gist of it.
