Enable 110 Volt AC Power Point with engine off
Old Mar 29, 2021 | 02:48 PM
Pushin2theLimit's Avatar
Pushin2theLimit
I have a 2019 F350. I want to keep the AC power point active after I shut off the engine, at least for a period of time. I haven't seen a whole lot on this topic. I saw a post where somebody had the dealership do it for them (by updating the computer). I also saw a video of someone doing it to an F-150 using Forscan. Anybody done this with Forscan with a Super Duty?
Old Mar 29, 2021 | 04:11 PM
mhoefer's Avatar
mhoefer
You can manipulate in Forescan, but you will quickly end up in a no start situation when you disable charge protect in Forescan. The truck will not even try to start if the voltage detected is below 11.0 volts. If you watch the voltage with the inverter running with the truck off, you will see how fast it goes down.
Mike
Old Mar 29, 2021 | 04:14 PM
ford390gashog's Avatar
ford390gashog
The stock inverter sucks so bad, I pulled mine out and put in a 600w unit with low voltage protection. It's always on and have not had a issue.
Old Mar 29, 2021 | 04:20 PM
Pushin2theLimit
Good information, thank you guys.
The Ace of Spades
Apr 5, 2018 08:33 PM
jmart273
6.7L Power Stroke Diesel
May 3, 2017 01:48 PM
69 f-100 aman
Aug 21, 2014 06:31 PM
Wmrdalydvm
Aug 30, 2013 08:17 PM
Dustin_86
Jun 15, 2004 01:06 AM
