AC plugs won't power laptop - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-19-2017, 06:56 AM
The Ace of Spades's Avatar
The Ace of Spades
The Ace of Spades is offline
The Ace of Spades is gaining momentum as a positive member of FTE.
Just wondering if anyone else has tried to power a laptop off either AC outlet? I can charge a cell phone off of them, but that's it so far. What gives?
Old 06-19-2017, 07:01 AM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.KubotaOrange76 has a great reputation on FTE.
Might as well not have them as far as im concerned, i havent been able to power more than a phone charger, no drill batteries, no laptop nothing
Old 06-19-2017, 07:05 AM
SDcrewzer's Avatar
SDcrewzer
SDcrewzer is online now
SDcrewzer is gaining momentum as a positive member of FTE.
Exclamation
I suspect the inverter's AC output is a "modified square wave" (MSW) rather than a true (or pure) sine wave like you get from AC wall outlets at home of from a high-quality TSW inverter. Some chargers (and other devices) aren't really compatible with MSW.
Check the laptop charger instructions and/or labeling, and try another "simple" load, such as a regular ol' 75W light bulb.
HTH,
Jim / crewzer
Old 06-19-2017, 07:29 AM
RugbyRef
RugbyRef is offline
Tim
RugbyRef is gaining momentum as a positive member of FTE.RugbyRef is gaining momentum as a positive member of FTE.
Originally Posted by SDcrewzer View Post
I suspect the inverter's AC output is a "modified square wave" (MSW) rather than a true (or pure) sine wave...
I believe you are correct. I read this somewhere else when I was having the same issue with my (now sold) '15 F350.
Tim
Old 06-19-2017, 08:47 AM
Seastacker
Seastacker is offline
Seastacker is starting off with a positive reputation.
I run my work lap top on mine all the time (Older HP Elite Book). I have a new one coming. If I have issues there I will report back if there is some compatibility issue with the new charger.
Old 06-19-2017, 08:54 AM
Nimrod
Nimrod is offline
Nimrod is starting off with a positive reputation.
HTH,
Jim / crewzer
This sounds plausible. I came to the conclusion it doesn't play well with smart chargers.
Old 06-19-2017, 09:07 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
I pulled the UPS out of my office and tried to run it on the 120v AC in my F-350. No joy. So far, the ability to run only certain things isn't a huge problem. But if I find I need that power then I'll look into changing the inverter.
Old 06-19-2017, 09:12 AM
k7lvo's Avatar
k7lvo
k7lvo is offline
k7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to behold
The 360* camera system uses the inverter. I can't imagine why it wouldn't work with a better inverter, but stranger things have happened....
Old 06-19-2017, 10:50 AM
manowell's Avatar
manowell
manowell is offline
manowell is starting off with a positive reputation.
I haven't had any issues charging camera or quadcopter batteries, or laptops. I want to put a meter on it now, though.
Old 06-19-2017, 11:29 AM
fordmantpw's Avatar
fordmantpw
fordmantpw is offline
fordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to allfordmantpw is a name known to all
manowell, what quadcopter do you have? My AC plugs won't charge my DJI Phantom batteries at all.
Old 06-19-2017, 01:32 PM
troverman's Avatar
troverman
troverman is offline
troverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud oftroverman has much to be proud of
Ford has the most powerful inverter currently available, at 400W. So if it doesn't work, a RAM or GM won't work either.
Old 06-19-2017, 01:55 PM
bushpilot
bushpilot is offline
bushpilot has a great reputation on FTE.bushpilot has a great reputation on FTE.bushpilot has a great reputation on FTE.bushpilot has a great reputation on FTE.
everyone understands the outlets only work when the truck is running correct?
I have no problem using, and charging my MacBook pro's (85w) using the AC outlets.
Laptop chargers consume less than 100w these days...and they do NOT need a purse sine wave inverter.
laptops (and even flat screen TV's) have their own internal/charger power supplies which condition the power....modified sine wave inverters work fine.
Old 06-19-2017, 01:56 PM
EightySecond's Avatar
EightySecond
EightySecond is offline
EightySecond is gaining momentum as a positive member of FTE.EightySecond is gaining momentum as a positive member of FTE.
Mine wouldn't run my laptop either, I was thinking there was something wrong with my receptacles in the truck but now it just appears to be some sort of crap design.
Old 06-19-2017, 02:24 PM
fordmantpw's Avatar
fordmantpw
It has to do with the QUALITY of the power, not the QUANTITY. Voltage plays a part too. If the voltage isn't high enough, many things simply won't work.
Old 06-19-2017, 02:36 PM
bushpilot
ok for those having issues, have you measured the voltage coming out of the outlet?
Quick Reply: AC plugs won't power laptop
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
