AC with 226 engine
Old Aug 28, 2013 | 06:53 PM
Wmrdalydvm's Avatar
Wmrdalydvm
AC with 226 engine
I've searched the previous threads but not come up with much. Surely someone has devised a way to add A/C to their truck with a 226 engine.
In south Texas where I am it is nothing short of essential if you want to drive in the summer. Any ideas?
Thanks
Bill
Old Aug 28, 2013 | 07:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check with "38 Coupe", he has AC on a 215, shouldn't be much different.
Old Aug 29, 2013 | 06:53 PM
38 coupe's Avatar
38 coupe
My A/C is in a sedan, but the basic approach is the same. I just realized I don't have any pictures of the setup. I'll try to post some in the near future.
I will also think about A/C in your pickup. I'll try to come back with some well thought out ideas in the next couple days.
Old Aug 30, 2013 | 05:07 AM
big job's Avatar
big job
So whats the problem. I'd say if you were adding AC to a 2013 vehicle, then you got problems.
Old Aug 30, 2013 | 08:31 AM
raytasch's Avatar
raytasch
Believe Nothing
I do not recall ever seeing AC on a flat head six but of course that does not mean it has not been done. I doubt if you'll ever find an aftermarket kit. I envision three items that would need modifications.
1. 12V conversion
2.Matching belt width for all belt driven accessories.
3. Bracket made for the compressor of choice.
You have lots of room in which to work so it should be doable.
I will be installing an [U]Old Air[/U] unit in my current '49 project F4. I don't have the three challenges you have as I have gone 12V and have an engine to which a compressor is easily adapted.
Old Aug 30, 2013 | 01:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1
1. 12V conversion
I'd be surprised if the stock fan is up to the task either. A condenser isn't likely to be as big as the stock radiator, making airflow problematic. A remote condenser with electric fan may be a better solution.
Old Aug 30, 2013 | 06:12 PM
Wmrdalydvm's Avatar
Wmrdalydvm
Not a problem--I certainly do plan to change over to 12V neg ground as it makes everything so much easier--Yes I am aware of the need for voltage reducers if I want to keep the old gauges but I'm leaning toward some newer retro type gauges so that wont be a problem
If necessary I can certainly add an electric fan to aid in cooling of the radiator as well as the A/C condenser--and eliminate the stock fan as well.
My questions was really directed more toward whether someone has fabricated a bracket that works well. I'm thinking I might as well switch over to an internally regulated alternator rather than stick with the generator. My local Gen shop has been trying to find a suitable armature for a 12V conversion with no luck
So my thought is to use the stock crank pulley, water pump and find a wide pulley to use on the new alternator. Then fab a new pulley that will fit in the front of the crank pulley and use the existing tapped holes into the balancer to secure the pulley. This will drive only the A/C compressor and I can use a narrow 3/8"-1/2" pulley for that
Any thoughts
Bill
Old Aug 30, 2013 | 06:31 PM
raytasch's Avatar
raytasch
Believe Nothing
Any thoughts
Bill
Since you're modifying the truck, go with an internal regulated alternator and forget about the generator. Electric fan, AC clutch coil, and in cab fan, and you're already at or above what most generator want to put out. Add headlights and you're in trouble. JMHO. Keep us abreast of your progress. Sounds interesting
Edit: BTW, Mac's sells a high output generator for the V8. Page 144 of their catalog. $$$$
Old Aug 30, 2013 | 08:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Stock V8 generator (wide) pulleys are the same ID, same offset, and very nearly the same OD as GM alternator pulleys.
FordPickMeUp
May 25, 2022 02:32 PM
69 f-100 aman
Aug 21, 2014 06:31 PM
ironmine
Garage & Workshop
Feb 19, 2008 07:17 PM
Doink
Sep 7, 2002 06:05 PM
