Electrical Question
Old Mar 25, 2021 | 06:35 PM
powerband73's Avatar
powerband73
Electrical Question
Hey guys. I have a 2016 F-250. I hooked my RV up to it, plugging it into the 7 Blade power and the running lights do not work. Neither do my tail lights. The brake lights and turn signals do work. My buddy came over and plugged into his truck and all the lights worked. I seem to have power to the 7 Blade port. I can't figure out why when plugged into my truck they aren't working. I looked at fuses, put a new 7 blade on it and still nothing. Any help would be much appreciated.
Old Mar 25, 2021 | 06:54 PM
Just Strokin's Avatar
Just Strokin
Did you check the truck female plug? I noticed a few times that the female connectors were "sprung" apart and would not make good connection. I could take a small screwdriver and push them together and it would make contact.
Also, did you take a test light and test your truck female 7 pin connector to make sure your lights worked?
Just a thought.
Old Mar 25, 2021 | 07:02 PM
Pugga's Avatar
Pugga
That happened on my truck and it was a fuse on the truck side. But I do agree with checking the connectors, they can spread and no longer make contact but they will usually make contact if you wiggle the plug. My bet is a fuse though.
Old Mar 25, 2021 | 07:26 PM
powerband73
Yes, I did. I even installed a new plug. I also checked with a test light. Getting power but no lights. It's one of the strangest thing I've seen.
Old Mar 25, 2021 | 07:28 PM
powerband73
That's what I was thinking, but I can't find what fuse it is in the diagram. I pulled a few that I thought it might be. The diagram doesn't list running lights specifically.
Old Mar 25, 2021 | 08:52 PM
KodiakF250's Avatar
KodiakF250
If you've got power at the plug but no lights, and your buddy's truck lights up the running lights, I'd look at a ground problem. You can connect a wire to a good ground location on your truck and then connect the other end to a good ground on the trailer. This is just a way of testing that makes sure your truck's ground is getting to the trailer. If it makes your running lights work, then you have to figure out where you are losing the truck ground going to the plug.
Old Mar 25, 2021 | 10:08 PM
powerband73
Thank you. I'll give that a shot. Much appreciated.
Old Mar 26, 2021 | 01:47 PM
powerband73
Update: I found the problem. It was fuse relay #29. All is good. Thank you guys for your input.
tater3000
Oct 16, 2019 08:05 AM
mkohut
16
Jun 8, 2018 09:36 AM
Pops05
Aug 2, 2015 05:53 PM
Lumpy78
Jun 19, 2009 04:18 PM
