need help identifying
the proper king pin kit for left steering side on 72 F750 dump truck driver side door tag
the correct king pin kit to purchase for 1972 F750 dump truck
with this tag on door
Moog shows for 1970 - 1977 with Hyd brakes from G90,001
part # 8500B 1.231 dia. 8.91 long with metal bushing.
part # 8500b010 1.241 dia. 8.91 long with metal bushing
part # 8500n 1.231 dia 8.91 long with nylon bushing
These are showing for a 7000lb axle. not showing a 9000lb axle in 72 they start in 73
The "M" in that axle code signifies a 7000# Ford axle with power steering.
Standard size king pin kit were Ford part number C7TZ3111A.
If you need a .010 oversize set they were Ford part number D3TZ3111A.
