21 450 used a full tank of def in 3100 miles. 200 of those miles were towing with the other daily driving not under any load. My 18 250 would go around 10k on a tank of def with no towing, 5k towing. I haven't checked mine yet but others are reporting a tank of def is used every 1500-1700 miles towing.
Is this considered normal? Never thought I would need a transfer tank for def....
I'm at 2800 kms with my '21 and my DEF gauge says 7/8 full. The range indicator says I can go another 10,000 km (6200 miles). About 1200 km was heavy towing.
IIRC, it's been discovered that the '20+ Trucks use significantly more DEF than '19 and earlier.
I’ve read a bit about that as well. One mention of an ecm flash to correct it. Can’t confirm if that helped or not. Makes zero sense. Hoping to figure out a solution or it may fall off.
