Def usage
Old Mar 23, 2021 | 01:48 AM
KCRebel's Avatar
KCRebel
Def usage
21 450 used a full tank of def in 3100 miles. 200 of those miles were towing with the other daily driving not under any load. My 18 250 would go around 10k on a tank of def with no towing, 5k towing. I haven't checked mine yet but others are reporting a tank of def is used every 1500-1700 miles towing.
Is this considered normal? Never thought I would need a transfer tank for def....
Old Mar 23, 2021 | 05:11 AM
senix's Avatar
senix
I used a tank every 3K miles with towing a lot.
Are you sure it was full when purchased?
Old Mar 23, 2021 | 08:54 AM
MadMaxx84's Avatar
MadMaxx84
IIRC, it's been discovered that the '20+ Trucks use significantly more DEF than '19 and earlier.
Old Mar 23, 2021 | 09:16 AM
B-737's Avatar
B-737
I’m at 3,000 miles and not even used a half tank of DEF. mixed towing probably 50%
Old Mar 23, 2021 | 09:31 AM
senix's Avatar
senix
Towing heavy or light...you have a 2020 or a 2019 or earlier?
Old Mar 23, 2021 | 09:32 AM
JESTERxHEAD's Avatar
JESTERxHEAD
That's on par with my 2020 F-450. ~500-750 mpg.
Old Mar 23, 2021 | 09:45 AM
4by4ord's Avatar
4by4ord
I'm at 2800 kms with my '21 and my DEF gauge says 7/8 full. The range indicator says I can go another 10,000 km (6200 miles). About 1200 km was heavy towing.
Old Mar 23, 2021 | 10:14 AM
B-737's Avatar
B-737
sorry forgot sig is cut off on mobile. It’s a ‘21. Towing light about 6,000 pounds.
Old Mar 23, 2021 | 10:37 AM
KCRebel's Avatar
KCRebel
Positive it was full upon delivery. Here’s a screenshot that shows the def range. Again this is 90% unloaded miles on the clock at that point.
Old Mar 23, 2021 | 10:40 AM
KCRebel's Avatar
KCRebel
I’ve read a bit about that as well. One mention of an ecm flash to correct it. Can’t confirm if that helped or not. Makes zero sense. Hoping to figure out a solution or it may fall off.
Old Mar 23, 2021 | 12:22 PM
senix's Avatar
senix
I don't know, at 438 miles per gallon, I rather have that then the regens when towing.
Badford
Jan 18, 2020 03:27 PM
sdm300
May 13, 2019 08:51 AM
Spoojr
Dec 14, 2017 07:07 PM
The Ace of Spades
Feb 21, 2017 01:33 PM
Stroker 94 1/2
31
Mar 14, 2009 10:54 AM
