DTE calculation question
Old Jul 18, 2017 | 03:29 PM
sdm300's Avatar
sdm300
I'm trying to figure out the DTE calculation setting in the DIC. I now have 2200 miles on the truck, 650 of those towing. I was getting around 16.5 mpg average unloaded, and 10-12 towing. With about 1/2 tank of fuel, I noticed that when the DTE calculation set to "normal", DTE is 199. With the DTE calculation set to "towing", DTE is 267. This doesn't make sense. If anything, it would be the reverse.
I have one trailer programmed, and, contrary to some reports here, automatically sets to the trailer when connected, and automatically sets to "no active trailer" when disconnected. Miles seem to only accumulate on the trailer profile when connected.
Anyone have any ideas on what is going on here? I would think that as the computer knows when a trailer is connected, it can differentiate between fuel consumption while towing and not towing, and track DTE accordingly. And the DTE calculation setting would determine which of the DTEs displayed. At least that's how I, as a software engineer, would design it. This is on a Platinum F350, Job 2 built in May 2017.
Old Jul 18, 2017 | 03:48 PM
fmf15e's Avatar
fmf15e
Trailering
DTE calculation
I also have some questions about DTE calculations. I have an April 18 2017 build F350 platinum 6.7 CCSB. I was not part of the TSB for fuel tank DTE. I put in a Titan tank and put 8 gallons of fuel back in my tank that was removed from the stock tank. Before the tank, the DTE showed 49 miles, after the new tank, DTE showed the same 49 miles. My trip to the station was 12 miles and by the time I got there, DTE showed 0 miles.
I filled the tank to the top of the filler neck (per Titan's instructions). My new DTE was 431 miles (my avg MPG was about 12.6, so this makes sense - 12.6 x 34 gal = 428.4) and the tank gauge showed full.
I changed my tank size to 55 gallons with ForScan and it only went to 513 - this would only be about 9.3 MPG, but I didn't reset or change anything else and tank shows full. I expected about 693.
Any ideas or anyone know how DTE is calculated? Is it based on avg MPG at the time you fill?
Thanks
FM
2017 F350 Platinum CCSB 6.7 4x4
2011 F250 Lariat CCSB 6.7 4x4 - sold
2008 F250 Lariat CCSB sold
Old Sep 24, 2018 | 10:40 AM
Citationman's Avatar
Citationman
I changed mine to 55 gal and it went from 450 to 753 dte. I also noticed normal vs tow that tow was more distance.
Old Sep 24, 2018 | 11:50 AM
rcorkum4's Avatar
rcorkum4
I agree that the truck should automatically change to towing DTE when it detects a trailer is connected and I have also found that at times the towing DTE is greater than non-towing. In my experience DTE is just a very rough guide to the remaining range on a tank of fuel. There is no way for the system to take into account the 30 mile 6% grade that you may encounter further along on your route. As a rule I start looking for fuel when I hit 1/4 tank in populated areas or 1/2 tank in remote areas. Once in West Texas I was towing against a very significant head wind with my previous truck and was saved from disaster by driving at 45 mph and the 3 gallons of gas that I had left over from running my generator.
Old May 12, 2019 | 09:56 PM
jaynesz28's Avatar
jaynesz28
how did you change to the correct tank in the 2017? I have forscan and cant find where to change the setting? I just installed the TITAN 55 gallon and cant figure it out. Ant help would be appreciated
Old May 12, 2019 | 10:00 PM
wrvond's Avatar
wrvond
My understanding is that the truck computes DTE more often when towing is selected. That’s the only difference. I don’t even bother switching between the two settings as the mileage is accurately computed either way.
Old May 12, 2019 | 10:03 PM
jaynesz28's Avatar
jaynesz28
As far as the new fuel tank being installed, it there a way to use Forscan to show the new 55 gallon tank size in the truck?
Old May 12, 2019 | 10:05 PM
jaynesz28's Avatar
jaynesz28
I cant access the IPC module and that's where I get stuck
forum says:
Change Fuel Tank Size IPC 720-03-01 xxx* **xx xxxx xxx* **xx xxxx Change asterisks to one of the following: 4 4A=30 Gal, 5 07=34 Gal, 5 EA=40 Gal, 7 19=48 Gal, 7 65=50 Gal, 8 22=55 Gal (This parameter is programmed to accept 4 digit Liters in this format XXX.x 55gal converts to liters of 208.198L so 208.2L rounded then drop the decimal 2082 decimal to HEX equal 822.)
Old May 13, 2019 | 08:51 AM
Kaadk's Avatar
Kaadk
Correct, I don't remember the exact numbers, but it's something like 'normal' averages over the last 250 miles, and 'towing' averages over the last 50. So your 'towing' DTE is more volatile than 'normal' towing. Once I learned that, I switched it to 'towing' and just run that one constantly. I'd rather have a more realistic number from current conditions in my DTE than a rolling average that might have me running out of gas sooner than I think because the average is off from current usage.
Spoojr
Dec 14, 2017 07:07 PM
SDTruckMan
Nov 2, 2017 06:04 PM
jermort
6.7L Power Stroke Diesel
47
Jan 26, 2011 06:16 PM
expy37at
Mar 19, 2008 10:55 AM
indebt
Aug 8, 2006 06:04 PM
