Odd ball 302
Old Mar 22, 2021 | 11:30 PM
wtroger's Avatar
wtroger
Odd ball 302
My grandson have an odd 302 in a 1981 f150 that originally was a 300 six. It has no casting number.and I know where to look. He put a edelbrock 4v manifold on it. With it in place it leaves the exhaust cross over ports open. The heads have no visible casting number. It does have a Ford emblem and cp in the casting and a date code 4f11 assuming 1984 June 11.
Called Edelbrock and talked to a tech and he said they had seen this before and don’t make a manifold that will work.
anybody know what this is. Or seen it before.
Old Mar 23, 2021 | 09:56 AM
DaveMcLain's Avatar
DaveMcLain
I'm not sure and it has been a really long time since I worked on one but I think that if the engine is a 255 that crossover port might be different. Those engines look very similar to a 302 but they have an oval shaped intake port.
Old Mar 23, 2021 | 01:30 PM
wtroger's Avatar
wtroger
ok took the intake off. those holes are blind they go no where.So we are putting the edelbrock manifold back on. It is not a 255. There are no casting marks in the valley indicating the size of the engnie. There is XXX cast mark up near the deck.
Old Mar 23, 2021 | 07:48 PM
DaveMcLain's Avatar
DaveMcLain
Those blind holes must be Ford factory tooling related because lots of their heads have them including the set of Boss 302 heads I was working on today. Totally different casting...same holes. It isn't unusual to see a 5.0 or 302 block that doesn't say so in the valley.
Old Mar 23, 2021 | 10:12 PM
Beechkid's Avatar
Beechkid
Could be a euro spec 302..... they were used in a landrover type vehicle back in the 80's IIRR...a good friend bought one (vehicle) in the US thinking he could get parts for it...oh what a nightmare...but it was good engine!
Old Mar 23, 2021 | 11:47 PM
Conanski's Avatar
Conanski
Casting numbers on the late model heads are on the bottom side of one of the center intake ports, with the intake off you should be able to see them with a mirror. There may also be a capital letter cast into an outside corner of the head just below the valve cover rail.
Old Mar 24, 2021 | 05:54 PM
baddad457's Avatar
baddad457
Those are indeed blind holes and are completely normal USA heads.
Old Mar 31, 2021 | 02:26 PM
Beanscoot's Avatar
Beanscoot
What holes are being referred to here?
Old Mar 31, 2021 | 02:32 PM
baddad457's Avatar
baddad457
The blind half inch (or so) holes above the exhaust cross over ports.
Old Mar 31, 2021 | 03:55 PM
Beanscoot's Avatar
Beanscoot
Right, the one obscured by the intake gasket?
Old Mar 31, 2021 | 04:25 PM
baddad457's Avatar
baddad457
yup !
53OlderThanMe
Oct 21, 2007 12:40 PM
*70F250*
Jun 11, 2007 01:12 AM
KULTULZ
Jul 6, 2005 06:09 AM
samahi72
Jan 25, 2005 07:46 PM
jkt
Jan 30, 2002 06:05 AM
