Windshield gasket
Old Mar 22, 2021 | 03:23 PM
longpark's Avatar
longpark
Windshield gasket
I have a 79 bronco that was leaking water around the windshield. I have had a shop replace the gasket three times and all three don't fit right. Corners not square or won't lay flat to the body, rubber not wide enough to cover the pinch weld on the body etc. Have used gaskets from Steele, Dennis Carpenter and a generic. Has anyone run into this or know of a gasket that will fit like the OEM?
Old Mar 22, 2021 | 04:02 PM
440 sixpack's Avatar
440 sixpack
The only one I've found that fits at all is the Precision brand. the others we threw away.
Old Mar 22, 2021 | 06:01 PM
dwirth's Avatar
dwirth
Precision for me as well. Others were too loose around glass
Old Mar 22, 2021 | 07:15 PM
VitaminC's Avatar
VitaminC
I had a pro install the $35 one from Bronco Graveyard (don't know who makes it.)
https://shop.broncograveyard.com/197...uctinfo/26016/
The installer actually complained that it was a bit too tight for his taste...still sealed up nicely though, and he got the metal trim back into place. FWIW
Old Mar 23, 2021 | 01:25 AM
black & blue 78/9's Avatar
black & blue 78/9
I get my gaskets at the jy. Look for a truck that has a cracked windscreen. Look at the condition of the seal, obviously no cracks in the rubber, but is older. Look at a number of different ones and you will start to see good usable gaskets compared to bad ones. I have had descent luck with this.
Old Mar 23, 2021 | 01:51 PM
nutter3's Avatar
nutter3
The guy at the local glass shop here claims that there is NO WAY to ever have these old vehicles with rubber gaskets seal up completely. He says they all leak, and I told him BS. After he replaced my last windshield, I went out and saw water pouring in after a rain storm. Definitely not happy.
I got some flowable silicone window sealer (permatex # 81730), squirted it in around the leaking side and it seems to have fixed it.
I'll have to find another glass shop next time.
Old Mar 23, 2021 | 02:07 PM
meangreen92's Avatar
meangreen92
Must've been an older guy, if he's knowledgeable about these 'grommet-style' seals.
X2 on the sealant!!
But one I used was more like roofing tar than silicone. It was a 3M product recommended for these rubber seals, and O'Reillys had to get it sent/transferred from 100 miles away.
I'm guessing that the OEM seals were a perfect enough fit in 1976 or whenever, that the assembly plants probably didn't use any sealant. But I'll bet that it was a staple on the replacement glass man's work bench, up until sometime in the last 15 - 20 years.
I reused my grommet seal when I swapped cabs, and ended up needing sealant. I'm also guessing that these seals were supposed to be a one-time-use deal.
blue351
Oct 4, 2020 02:31 PM
JoeKan
Sep 16, 2019 07:50 PM
kountzecobra
Apr 16, 2017 07:32 PM
johnfin1
Aug 27, 2016 03:35 PM
berkad
Jul 31, 2002 12:38 AM
