Steering column alignment
Old Mar 23, 2021 | 02:13 PM
mmaltby's Avatar
mmaltby
OK. I have replaced the steering box and rag joint on 1979 f150 2wd. I am having heck of a time aligning the steering column. the steering wheel is out of round by about 3/4 inch. I have centered the rag joint and loosened the bolts under the dash and the firewall. jiggled the hell out of the steering column to no avail. I would appreciate any feedback. Also, the rag joint came with two plastic gizmos which I'm not sure what to do with I'm thinking they may be to help in aligning the two pins on the rag joint . Also, there is a metal plate that came with the rag joint which I'm not sure what to do with. The original rag joint didn't have the aforementioned extras.
Thanks!
Mike
Not the actual rag joint but shows plastic doodads and metal half moon metal part
Old Mar 23, 2021 | 02:21 PM
ford390gashog's Avatar
ford390gashog
The extra metal piece is a safety, it prevents you from losing steering if the rag joint fails.
Old Mar 23, 2021 | 02:25 PM
mmaltby's Avatar
mmaltby
Thanks man! That makes sense!
RustyTrustyF150
Apr 4, 2014 08:14 PM
78150custom
Sep 9, 2009 12:04 PM
IDIDieselJohn
Jul 14, 2009 05:47 PM
fasttang757
Jan 28, 2008 07:32 PM
Comegetsome
27
Jan 14, 2005 10:46 AM
